Speakers and amp help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-03-2013, 09:04 AM - Thread Starter
Mmasterg314's Avatar
I hope this is in the right place. Guys I have a 9 k budget, I am going to spend near $2500 on projector and screen which I am researching leaving $6500 left. I would like some oppinions on speakers 5.1 to go listen to no higher then 4 k. I would think this is a good amount on a speaker system. I can get a sub later if need be. I see some speakers that are 8 ohms and some at 4. Some amps say highter wpc into 4 ohms. Please keep in mind I will only be doing audio this one time and I like some thump. My master bedroom is where this is going keep in mind the size 20 by 15 and 15 by 10 is all one room with vaulted ceilings. I think the speakes should handle at least 200 wpc or would like them to.
Next question what is a good amp/ pre amp I will have about $2500 left maybe $1500 for amp 1k for pre amp I could go $500 higher if need be. Thanks
Mmasterg314 is offline
post #2 of 7 Old 02-03-2013, 09:58 AM
padgman1's Avatar
^^^^ I wish I had your budget ( and your bedroom space!!)......
Here's a thread dealing with main floorstanding full response speakers to start
http://www.avsforum.com/t/1437010/2-000-3-000-tower-speaker-comparison-need-help-picking-the-contenders-for-a-shootout
If you want "thump", though, you will need subwoofers, and at least 2 for that size area............many options abound from Hsu, Rythmik, SVS and Power Sound Audio ( these are the current favorites on this forum)
You can save some by getting bookshelves for your L/R and letting the subs handle everything below 80Hz......
Others here will hopefully chime in, as I personally have no experience with speakers in your budget range.......
padgman1 is offline
post #3 of 7 Old 02-03-2013, 11:17 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
We use James loudspeaker. We have a Pioneer and Denon receivers. This is the James new line.
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=32&sr=1
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #4 of 7 Old 02-03-2013, 07:30 PM - Thread Starter
I do not want inwalls. I see great reviews on Martin Logan ESL Electro static for $2200 leaving $1800 for center and l/r rear speakers. I also see MLTheos for $2500 with $1500 for rears and center, I can add sub later if I go this high end. I saw good reviews on thiel SCS4T. Dynaudio seem awesome also but for the money the other 3 may be front runners. I know I need to go listen to a bunch of speakers but figured I get some opinions to cut down on some time.
post #5 of 7 Old 02-03-2013, 08:32 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
Ok...
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=31&sr=1
Paradigm
Def Tech
Triad
Atlantic Tech.
Control4
post #6 of 7 Old 02-03-2013, 08:57 PM - Thread Starter
No Theos 2500 each,lol.
post #7 of 7 Old 02-03-2013, 09:33 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
Thought you wanted opinions on other speakers???
If you like the ones you have listed buy buy buy and enjoy.
Control4
Reply Speakers
