Question on polk rti12's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-04-2013, 10:55 AM - Thread Starter
paul112233's Avatar
I just purchased a set of RTi12's with the csi5 center and a pair of rti6 surround, with a polk 8"sub.
I have an Onkyo txnr808 running everything. It's a 7.2 receiver with 135 watts /channel at 8ohms ans 20-20k hz.
I have the RTi'12s biamp.
I set up Audyssey to set up speaker adjustments..
The problem I have is that I am not getting much base from the RTi12 speakers, and do I need a seperate amp or will this receiver be able to run them well? I have the RTi12's as full tower speakers on the receiver.
Any advice would be useful.
Thank you.
paul112233 is offline
post #2 of 2 Old 02-04-2013, 11:04 AM
TheGSRGuy's Avatar
Quoted: 17 Post(s)
The receiver can certainly drive them, yes. Is it optimal? Not really.
Let Audyssey do its job. You have a subwoofer to fill in the deeper bass.
If you really think the bass is weak, disconnect the sub and re-run Audyssey to see if it improves.
Marantz AVR & monoblocks + MartinLogan Motion 3.1 setup
TheGSRGuy is offline
Reply Speakers
Polk Audio Speakers Rti 12
