Do you need big speakers for big sound? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2013, 08:22 AM
Bill Fitzmaurice's Avatar
Liked: 4668
Originally Posted by Kain View Post
By the way, I'll have the couch a little less than 3 feet from the back wall in room 2.
http://www.padrick.net/LiveSound/CancellationMode.htm
Bill Fitzmaurice is online now
Old 02-17-2013, 08:28 AM - Thread Starter
Kain's Avatar
Quoted: 1235 Post(s)
Liked: 339
But won't there always be some sort of cancellation no matter how well I try to place the speakers and/or the seating? confused.gif
What would you recommend for room 2?
Kain is offline
Old 02-17-2013, 08:34 AM
Liked: 4668
Cancellation will always occur, but some frequencies are much worse than others. Basically you want to avoid cancellations within the 20-150Hz range. To a great extent you can do so with seating placement, but the longer the wavelength the more difficult it is. That's where multiple subs come in. You may be in the null zone of one sub, but not in that of another at the same frequency.
Old 02-17-2013, 08:45 AM - Thread Starter
Kain's Avatar
Liked: 339
By the way, even if the couch is about 3 feet from the back wall, the left/right surrounds will be placed a little higher (not at ear-height while sitting down) on the back wall and toed-in slight to the listening position. Wouldn't this make the distance from the couch to the left/right surrounds (placed on the back wall) around 4-5 feet? With this setup, the cancellation occurs between 55-70 Hz but by then the subwoofer would have taken over because I will be crossing the speakers at 80 Hz. Will this work?
Kain is offline
Old 02-17-2013, 10:57 AM
Liked: 4668
Look at the angles. The surrounds aren't aimed at the back wall and then reflecting off it. The easiest way to compensate for the distance to the rear wall is to have a sub placed to the side and rear of the couch. But you then have to be aware of the reflection distances from that sub to the side walls and the LP.
Old 02-17-2013, 07:16 PM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 108
Originally Posted by FOH View Post
Mark is on record stating the 8C is actually much better suited for small spaces combined with the use of Audyssey, or other automated EQ'ing tools.
Do you know what his definition of small is?
I also like a big, full sound which is why I usually end up with B&W when I need new speakers, but I don't know if they will go the distance with HT. Is Mark still doing AD / DA with all of his speakers? I understand digital correction results in a net gain for his speakers, but would rather not use speakers with built in EQ since I will need to EQ for the room anyway. Still, I figure they're worth a look. Does Mark have a demo pair he loans out, or a reasonable return policy?
I also wonder what the significance of room volume is. Genelec has a speaker selector tool and it's based on both listening distance (which I understand) and total cubic meters of the room (which I don't). Does the ability to "fill the room with sound" make a difference in the big-ness of the sound?
rabident is offline
