guys, please give me an advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-05-2013, 11:09 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
guys, i already have denon 1612 receiver. i am looking for 5.1 floor speakers set up. i get accross on this set, is this a good set for my receiver? and anybody knows if this is a good set of speakers? http://www.amazon.com/Jamo-426-HCS-WENGE-5-Piece/dp/B003GGXGU6/ref=cm_cr_pr_product_top
any reccomendations? my only budget is like $300-400 for floor standing 5.1 set up.
caloyzki is offline
post #2 of 9 Old 02-05-2013, 11:17 AM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
I think in that price range, the Jamo set is about as good as you will get...as long as you are aware that it is 5.0, not 5.1!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #3 of 9 Old 02-05-2013, 11:22 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
oh yes, sorry, i mean its only 5.0 i will buy a sub for that. but is that speakers are main entry speakers for my denon 1612 receiver? or should i buy 3.0 set up? any reccomendation any speakers sir?
caloyzki is offline
post #4 of 9 Old 02-05-2013, 11:34 AM
zieglj01's Avatar
Quoted: 1710 Post(s)
Liked: 1626
Look at the Boston A250 tower - white with black grill
http://www.accessories4less.com/make-a-store/item/BOSA250WHA/BOSTON-ACOUSTICS-A250-2-Way-Dual-5.25in-Floor-Standing-Speaker-EA-White/1.html
Boston A225C center - in black
http://www.accessories4less.com/make-a-store/item/BOSA225CGBA/BOSTON-ACOUSTICS-A225C-2-Way-Center-Channel-Speaker-Black/1.html
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #5 of 9 Old 02-05-2013, 12:49 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
^^^^hanks a lot. any rear surround that i cam pair for this set up?
caloyzki is offline
post #6 of 9 Old 02-05-2013, 02:28 PM
Knight Operator's Avatar
thats a tight budget. i was going to recommend the jamo, but you beat me to it, and pair it with an BIC f12 for 180 more bux. that would be it for that price range. What i went with at a slightly higher budget was the BIC FH-6t towers (120 each), FH6-LCR center (100), and DV-62si (100 pair) for all 4 of my surround channels. Thats 560 w/o a sub, still recommend the f12; i already had 3 subs. sounds amazing. i had all polks before.
Buy here, use make best offer, and negotiate the price mentioned above.
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1767&sc=32
Knight Operator is offline
post #7 of 9 Old 02-05-2013, 05:34 PM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 19205
+1 fwiw,imo the boston acoustic a360's$360 and the a250 $200 are a great bargin. as for surrounds take a look at the pioneer sp-bs22 on amazon $90
i'm so laid back,i'm laid out
smasher50 is offline
post #8 of 9 Old 02-05-2013, 05:47 PM
justindo's Avatar
I own the Jamo setup and it's decent but excellent for the price. The Bostons are probably a bit better if you can live with white. If not, I'd go with the Jamos. You could get them and the highly recommended sub (wait for it to go on sale for $300 shipped) below for around your budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
justindo is offline
post #9 of 9 Old 02-06-2013, 05:30 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
guys thank you for the advices i really appreciated, i know that is the only budget i can afford at this time,and for that budget i cant choose the best speakers on that tight budget. i will look for these speakers and maybe wait to get on sale. smile.gif
caloyzki is offline
Reply Speakers
