Polk Monitor 75T vs Polk Monitor 70 Series II - Review & Comparison - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 36 Old 02-05-2013, 04:30 PM - Thread Starter
Adoniram's Avatar
I recently purchased the Monitor 75T floor standing speakers for use in my media room. I already had the Monitor 70 Series II as part of my main family room home theater, so I thought I'd do a little side-by-side comparison.
You can see the specs and features of each speaker here:
Monitor 75T
In 2011, I purchased the Monitor 70s for $220/ea on sale. In 2013, I got the same price for the 75T. Awesome biggrin.gif
So here they are, standing side-by-side:
Cat used for scale purposes:
I played 4 songs (Mario - Because she said hi, Frou Frou - Must be dreaming, Mozart - Requiem, Carl Orff - Carmina Burana) and 1 movie (Lords of the Rings: Return of the King) as my test.
Speakers were plugged into an Onkyo TX-NR609 which was set to Stereo only. The subwoofer was left unplugged, so the only sound came from the 2 speakers themselves. The receiver was set in Bi-Amp mode, for whatever good that does (next to nothing since the speakers have passive crossovers).
Anyway, all that to say the conditions were the same for each test (same receiver, same settings, same bi-amp configuration, same songs, same movie, same room, same cat...)
My personal feelings:
I have absolutely loved the Monitor 70s so my expectations were high for the 75T models. The 70s produce a great range of lower-mid to high frequencies and have crystal clear definition. They can produce lower bass, but not with a great deal of power or feeling. They really need to be paired with a sub. Some lower frequencies can actually hit pretty hard, but this is more in the 200Hz+ range. Unfortunately, without a sub, this can make the bass sound inconsistent. With a sub, everything sounds perfect. The highs are super clear, and voices sound amazing. Special effects of course are stunning. The clashes, clanks and slashes of medieval battle make it sound like your own head was being lopped off.
The 75T was nearly identical in all its qualities, but with a few exceptions. The speakers seem capable of slightly (and I mean slightly) lower frequencies, with a little more power. Still, a sub is required for full effect. The highs are just as clear, but perhaps not quite as ear-piercing. I'm not sure if it was slightly attenuated, or just more controlled.
At the end of the day, you'd be hard pressed to really discern a difference between the 2 sets. I would say that the 75Ts are just as good as the 70s, and there is no need for hesitation if you're thinking about buying. They go on sale frequently on NewEgg and are an incredible value! If you have 10x their price in disposable cash, I guess you might look at a different brand or set, but honestly, be prepared to spend that much more to get anything "better." I'm honestly not sure if anything other than scientific instrumentation could detect the difference in more expensive gear.
Happy shopping, and I hope this helps everyone understand the slight differences in the new set.
Nick_WI, natchie and Majicjester like this.
Adoniram is offline
post #2 of 36 Old 02-05-2013, 04:52 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Thanks for the write up. I've suspected the 75's were nearly identical to the 70's. It's good to hear from someone with first hand experience with both. I once tested the 70' s against the tsi500's and heard no real difference between the two in my room.
Have you ever heard the 70's powered by a 200 watt amp? I've got my 70's running off an xpa-5 and they can sure hit the lower frequencies with more authority then the did being ran off my denon 1611 or onkyo 809.
Majicjester likes this.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 36 Old 02-05-2013, 09:25 PM - Thread Starter
Adoniram's Avatar
No, the only thing I've heard them powered by is the Onkyo receiver. I'll be purchasing another Onkyo unit whenever one goes on a decent sale... I got the TX-NR609 for $196 new on Amazon, and I'm holding out hope that a similar sale will occur for the TX-NR616 or 717 models... But even then, I assume the output would be very similar. The 717 would definitely give it more juice, but the 609 I have now already pushes them past comfortable listening levels at approximately 70%
Adoniram is offline
post #4 of 36 Old 02-05-2013, 11:10 PM
Nick_WI's Avatar
I've been waiting for some feedback about the new 65T and 75T. Thank you for sharing!
Visiting since 2002!
Nick_WI is offline
post #5 of 36 Old 02-06-2013, 12:44 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I like the new look of the 75 and 65. Agree that for the money they are excellent speakers. I own the Monitor 70 II, and they sound excellent. I regret not buying the CS2 when it was available and on sale for $99.99.
GusGus748s is offline
post #6 of 36 Old 02-09-2013, 01:08 PM
XStanleyX's Avatar
Liked: 1269
You still looking for a CS2 Gus? The price isn't all that bad.
http://stores.ebay.com/Polk-Audio-Direct/Center-Channel-/_i.html?_fsub=160111419&_sid=686154689&_trksid=p4634.c0.m322
XStanleyX is offline
post #7 of 36 Old 02-15-2013, 09:01 AM - Thread Starter
Adoniram's Avatar
Just a quick note for anyone who is concerned about overall width, since the feet protrude:
The actual overall width including the feet is 9.5" but the feet are easily removable. Here's a pic showing the screws in the feet. Nevermind the tape measure... perspective is just bad in this shot
Adoniram is offline
post #8 of 36 Old 02-15-2013, 09:01 PM
B00BNooB's Avatar
I have one Monitor 70 that I purchased used for 50$. Since the 75t is on sale right now, do you think I could pair one m75t with one m70? Or would the timbre be off?
B00BNooB is offline
post #9 of 36 Old 02-18-2013, 06:08 PM - Thread Starter
Adoniram's Avatar
The timbre would definitely be off, but not by much. However, if you play movies/music at high volume, I think it would be enough to bother you. Also, the tweeter is a tad higher on the 75t, so it might even sound "uneven" to your ears, but depends on the acoustics of your room. I would not recommend it...
Adoniram is offline
post #10 of 36 Old 02-18-2013, 09:44 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Glad you posted your review, Adoniram. I know people have been wondering how similar the Monitor II series and the new Monitor T designated speakers are.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 36 Old 02-18-2013, 11:30 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Even though I have the 75T's, I think the 70's look A LOT better.. haha.
The tweeter is also more ear level on the 70, but whatever.
Positioning looks a bit different than in that pic, that was the rough draft.
GaryWA is offline
post #12 of 36 Old 02-19-2013, 12:02 PM
B00BNooB's Avatar
B00BNooB is offline
post #13 of 36 Old 02-27-2013, 09:27 AM
variat79's Avatar
Thanks for this. I got a pair of Monitor 70's and have been kicking myself for not getting more to finish my set.
Quick question, I have a cs2 for the front. Should I put the Monitor 70's in the front, the 75T's, or does it really matter?
variat79 is offline
post #14 of 36 Old 02-27-2013, 11:20 AM
XStanleyX's Avatar
Liked: 1269
Doesn't really matter. The CS2 will timbre match either set. Just whatever looks best to you.
post #15 of 36 Old 02-27-2013, 06:41 PM - Thread Starter
Adoniram's Avatar
I haven't done a side-by-side comparison of the 25C versus the CS2, but I would bet they are also very similar. Given that it's a center speaker (and isn't matching another unit somewhere else in the room), I'd say you were safe with either.
Adoniram is offline
post #16 of 36 Old 03-12-2013, 10:17 AM
french_guy's Avatar
Quoted: 14 Post(s)
So that means TSi500, Monitor 70-II and Monitor 75T are kind of all the same...meaning no big sound difference?
I have a pair of TSi300 and would like to upgrade, but keep my CS2
TSi500 or Monitor 75T or 70-II?
Looks like I can't find Monitor 70 anymore (1st serie)......( I am looking for the Cherry color)
By the way, what's the difference between Monitor 70 and 70_II?
french_guy is offline
post #17 of 36 Old 03-12-2013, 10:45 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
The 75T are on sale for $199.99 the cheapest I've seen so far at newegg.com.
post #18 of 36 Old 04-20-2013, 08:54 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
The 75T is now $180 each at the Egg with the always popular promo code, expires 04/20/13.
I have fronts which I built from Madisound and have high quality MTM components, but only 5" mid/woofers right at $400 pair. I was looking for a tower I can bi-amp with my Onkyo 717, but I don't know if this is the upgrade I am looking for.
Your review is very compelling, because I don't trust any of the "reviews" pro or con that are listed on the Egg or Amazon. Thanks for posting the review.
wvu80 is offline
post #19 of 36 Old 04-20-2013, 09:01 PM
cel4145's Avatar
Liked: 2984
Bi-amping with AVRs doesn't really accomplish much (if anything). The real benefit of bi-amping comes from active crossovers and separate amps. With AVRs is more marketing gimmick than benefit.
cel4145 is offline
post #20 of 36 Old 06-04-2013, 10:12 AM - Thread Starter
Adoniram's Avatar
75T floor standing speakers just hit $169 for 2 days at newegg! Promo: EMCXPXS22
takedatewitchu likes this.
Adoniram is offline
post #21 of 36 Old 06-04-2013, 10:51 AM
brawk's Avatar
brawk is offline
post #22 of 36 Old 06-04-2013, 03:07 PM
KaufmanD's Avatar
Thanks for the post! Got them for $169 each at Newegg. Now, how do I hook them up to the home theatre system without the wife noticing?
KaufmanD is offline
post #23 of 36 Old 06-04-2013, 11:24 PM
na300zx's Avatar
Just picked up two. I have onkyo 818 to power these. I also would like to buy a 25c and 45b to complete. This sound good? I have two 12" dayton 1200 to go with these when the set is complete. Would there be an advatage to go 7.1? Saw a post where a guy used another pair of 75t for fronts. Overkill?
na300zx is offline
post #24 of 36 Old 06-05-2013, 08:38 AM
takedatewitchu's Avatar
I just picked up this exact same set (75t, 25c, & 45b) to go along with a PSW505 sub and a Denon AR1613 receiver. Should all arrive today (except the 75ts will be in tomorrow). Needless to say I'm like a kid waiting to open up my Christmas presents since this is my first dive into anything more than a $200 HTIB.
Oybub1952 likes this.
takedatewitchu is offline
post #25 of 36 Old 06-05-2013, 08:57 AM
na300zx's Avatar
I would complete the set but the 25c is not in stock at Newegg. I see it went on sale for $130 a few days ago. This could be the reason for it being out of stock. I am also excited because I currently have the Jamo s420 as my current setup. Someone also recommended the Klipsch rf-42 series instead of the monitor 75t set. Any thoughts on this?
na300zx is offline
post #26 of 36 Old 06-05-2013, 09:31 AM
The sale must have been why out of stock. Newegg ran a 4 day sale, and that's when I ordered mine and they have shipped. Glad to hear I got to them before they were out. I also thought about the RF-42s instead of the 75ts. They looked very comparable, but I like the look of the 4 drivers as opposed to two. Plus, this way my whole set matches. I've heard nothing but good things about the RF-42s, but haven't seen them in person.
post #27 of 36 Old 11-24-2013, 02:17 PM
Subdusted's Avatar
There's never too much amp power. And you need the power to listen to music at LOW volumes, if your amp is not powerful enough you will lose half of the details, dynamics and bass . Another reason, with a weaker amp/receiver you are more likely to fry your tweeters.
Subdusted is offline
post #28 of 36 Old 11-24-2013, 02:24 PM
Subdusted's Avatar
[quote name="Adoniram" url="/t/1456569/polk-monitor-75t-vs-polk-monitor-70-series-ii-review-comparison#post_22927912" If you have 10x their price in disposable cash, I guess you might look at a different brand or set, but honestly, be prepared to spend that much more to get anything "better." I'm honestly not sure if anything other than scientific instrumentation could detect the difference in more expensive gear.
[/quote]
In that you are very wrong. A small step up, let's say to RTiA 5 would make a noticeable difference. And if you go all the way to RTiA 9 paired with 600 watt monoblocks ( Emotiva XPA-1 Gen2 ) - the difference will be night and day. The depth and width of the soundstage, the body and richness of the sound.. And that's just Polk Audio, an average Joe speaker brand.
post #29 of 36 Old 12-25-2013, 05:20 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Are the cherry colors the same from the 70 to the new 75T?
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #30 of 36 Old 09-27-2014, 07:42 PM
Liked: 1
Question
Sooooo, if I could get the 70's at a lower price what reason would there be to pay more for the 75's? I don't care at all about looks....
OdinGOW is offline
Reply Speakers
Polk Audio Monitor 75t Four Way Ported Floorstanding Speaker , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker
