Do diamond domes sound different than beryllium domes? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 38 Old 02-09-2013, 11:25 AM
Bill Fitzmaurice's Avatar
Liked: 4648
Originally Posted by inky blacks View Post
Are hard domes even the preferred way to go?
It's a matter of stiffness and light weight. Silk is obviously light, but it will only take so much power before it lacks adequate stiffness. That's why you see mostly metal diaphragms in pro-sound compression drivers.
Bill Fitzmaurice is offline
post #32 of 38 Old 02-09-2013, 01:09 PM
Quoted: 911 Post(s)
Liked: 490
Originally Posted by Bill Fitzmaurice View Post
Originally Posted by Will2007 View Post
It's about being able to charge $600 more per speaker for diamond dome tweeters, isn't it?
Yep. And if you look at how they're made the diamonds are literally a dust coating. There are better ways to make domes out of carbon, it's just a matter of time before they appear.
Pioneer has done drivers on and off in something they call "ceramic graphite" (see this 1980s speaker and this current model.
According to the Stereophile review of the older one, it's kind of brittle stuff.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #33 of 38 Old 02-09-2013, 01:21 PM
Theresa's Avatar
Liked: 51
My center channel (DIY) uses the ScanSpeak Aircirc fabric dome. A wonderful tweeter especially for vocals. There is a new "Aircirc" Beryllium dome from ScanSpeak that has a smoother frequency response. Hard to justify $520 for a tweeter whose cheaper sisters have smoother response though.
Theresa is offline
post #34 of 38 Old 02-09-2013, 01:34 PM
JD in NJ's Avatar
Liked: 36
Waiting for the six thousand dollar graphene dome tweeter?
JD in NJ is offline
post #35 of 38 Old 02-09-2013, 01:45 PM
Liked: 4648
Since there are people stupid enough to spend $200k on a speaker I have no doubt that $6k tweeters will be along at some point.
post #36 of 38 Old 02-09-2013, 02:23 PM
Theresa's Avatar
Liked: 51
Look at these two tweeters.
SILK DOME
http://www.parts-express.com/pe/showdetl.cfm?partnumber=275-070
RING RADIATOR
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1016
Polk is making cheap tweeters out of silk and plastic, which I have not heard yet, but which sounds like a great idea to me. They should last a long time,…longer than silk alone or fabric alone.
I think that the difference between a good soft dome and a good hard dome is greatly exaggerated these days. Resonances of hard domes have been moved into the inaudible range above 20kHz while some soft domes have smooth response to above 30kHz.
Theresa is offline
post #37 of 38 Old 02-09-2013, 07:48 PM - Thread Starter
inky blacks's Avatar
Moissanite /ˈmɔɪsənaɪt/[4] originally referred to a rare mineral discovered by Henri Moissan having a chemical formula SiC and various crystalline polymorphs. Earlier, this material had been synthesized in the laboratory and named silicon carbide (SiC).
http://en.wikipedia.org/wiki/Moissanite
Moissanite would be cheaper than diamond and would probably work in a tweeter.
Cubic zirconia for tweeter use?
inky blacks is offline
post #38 of 38 Old 05-17-2014, 10:21 PM
Tom Wenceslao's Avatar
It appears that someone is selling a 2"x 4" Single Layer Graphene Sheet on Copper Foil on ebay for $850.
http://www.ebay.com/itm/Single-Layer-Graphene-Sheet-on-Copper-Foil-/201088327221
I wonder how this will sound if this is shaped into a dome (with voice coil and rubber surround added of course) and dropped into an existing tweeter. Should be enough to make 2 good ones or possibly 4 if the driver is small enough.
Tom Wenceslao is offline
Reply Speakers
