What speakers to buy: Pioneer SP-BS22-LR, Definitive Technology 350 or Usher Audio S520 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-06-2013, 09:12 PM - Thread Starter
EugF's Avatar
Help needed to decide which speakers are better, as they are all very good, so it is hard to make a decision?
Pioneer SP-BS22-LR
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG/ref=cm_cr_pr_product_top
http://www.amazon.com/Definitive-Technology-StudioMonitor-Speakers-Black/dp/B000TD6REQ/ref=cm_cr_pr_product_top
Usher Audio S520 Multiple award winners...
http://www.usheraudiousa.com/files/reviews/s-520-avguide.pdf
http://www.usheraudio.com/news/Hi%20Fi%20World%20Feb%2007%20520%20Group%20Test%20Review/index.htm
Right now i have this small amplifier:
http://www.ebay.co.uk/itm/Fanmusic-DT-2050A-2x75W-TK2050-TP2050-T-AMP-USB-REMOTE-Tripath-Class-T-AM-black-/180693401217?ssPageName=ADME:X:RTQ:GB:1123
my current speakers are Microlab solo 6
and i made them passive
http://www.modsynergy.com/review175.html
http://www.kitguru.net/site-news/announcements/zardon/microlab-solo-6c-speakers-review-big-sound-for-a-small-price/
so my plan is to upgrade, will i get any improvement in sound or is it going to be the same?
I was also thinking to upgrade an amplifier in order to get more out of Microlab solo 6, then I would keep Solo 6.
any advise will be appreciated.
EugF is offline
post #2 of 2 Old 02-18-2013, 04:20 PM
KHRobertson's Avatar
I'm far from an expert on these matters, but looking at the "Fanmusic" amp - I'd say upgrade to a newer receiver first. It doesn't even appear that your amp has digital inputs, which will limit the fidelity of the music to which you're listening unless you're listening to strictly analog media such as vinyl on a phono. If you listen to CDs or other digital music, you will want digital audio inputs - either coaxial or fiber optic - which provide an exactly translation of the music rather than an analog approximation of the music.
It sounds like you're a strictly 2 channel audio kinda guy, versus wanting an AV Receiver to control a home theater setup. In that case, I would go with the Def Tech speakers because they have the largest woofers and I've heard that they are well regarded for producing a full frequency range for stereo listening in a fairly compact package. If you were wanting an AV surround sound setup with multiple channels and a subwoofer I might suggest the Pioneers as better bang for your buck.
KHRobertson is offline
Reply Speakers
