NEED youre opinion guys on this unit. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-07-2013, 11:56 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hi guys is this thing is worth to buy? or it is better to get a set up? my only budget is $500-600. http://www.accessories4less.com/make-a-store/item/ONKHTS3400/Onkyo-HT-S3400-5.1-Channel-Home-Theater-Package/1.html
caloyzki is offline
post #2 of 23 Old 02-07-2013, 01:34 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
You have a 500 to 600 dollar budget, and you are looking at that option? I would skip it.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #3 of 23 Old 02-07-2013, 01:42 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
I try to be more helpful than the post above me but you haven't provided much information. so we know your budgets, but what about the room, your preferences, your previous speaker experiences? Anything more to add?
I would tell you and any friends I knew, if i had that little information, buy a nice set of bookshelves, find a clearance receiver and add to it as you can budget.
jbdan likes this.
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
post #4 of 23 Old 02-07-2013, 01:44 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
post #5 of 23 Old 02-07-2013, 01:53 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
I'm not trying to be rude, as I can see you post here very often.....
I would save my money and buy the Onkyo set before those Pioneer speakers. While they do sound decent, they are really priced at what they are worth.
They certainly did not sound amazing, to me anyway.
Wouldn't a set of Infinity, JBL, or Boston sound so much better?
skidawgz is offline
post #6 of 23 Old 02-07-2013, 02:12 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It all comes down to taste, preference and choice - there will be some who may not prefer the Pioneers.
I try to weigh out a speaker in my home - and Pioneer is real popular all around > I will take the Pioneer
over the entry level JBL, Infinity, Polk, Klipsch, and some entry level PSB, Paradigm and Boston.
Now if the OP really wants to build up - then I would go with the Denon, JBL subwoofer, and a pair of the
Cambridge Audio S30 speakers.
I for sure would skip that Onkyo package - however, to each their own.
Who AM I
post #7 of 23 Old 02-07-2013, 02:19 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
thanks guys, but my wife wont let me spend 600 on HT set up. that is why i came across on that unit for 200 including everything. but i am not sure if in the long run i will regret it buying those onkyo package. what if i will buy denon 1612, jamo s 199 at amazon and polk psw10? is that a good decent entry level for HT with that kind of budget?
caloyzki is offline
post #8 of 23 Old 02-07-2013, 02:27 PM
Bill Fitzmaurice's Avatar
Liked: 4631
You will. $200 is about what you'll pay for a worthwhile AVR. If you want to chip away at it do an AVR and a $150-$200 center, when you can add the rest bit by bit.
Bill Fitzmaurice is online now
post #9 of 23 Old 02-07-2013, 02:38 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
that is what i a thinking about. so denon 1612, jamo s and polk psw10 not a good combo, sir?
caloyzki is offline
post #10 of 23 Old 02-07-2013, 02:44 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would aim for another subwoofer - or save up a little - your choice
Who AM I
post #11 of 23 Old 02-07-2013, 02:46 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
ok. how about denon 1612, jamo s, and dayton 1200 sub?
caloyzki is offline
post #12 of 23 Old 02-07-2013, 02:53 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I expect the sub to be better than some old RadioShack subwoofers.
If $129 is your max budget, then try it out - if may work out for you.
Who AM I
post #13 of 23 Old 02-07-2013, 03:36 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
but jamo will be fine with denon 1612 receiver?
caloyzki is offline
post #14 of 23 Old 02-07-2013, 03:43 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Yes
caloyzki likes this.
Who AM I
post #15 of 23 Old 02-07-2013, 03:53 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Are you against adding pieces in time? I would buy $400 bookshelves and a $200 receiver. Something similar to a BW 685 but without the premium BW pricetag.
skidawgz is offline
post #16 of 23 Old 02-07-2013, 04:15 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
^^^ send me a link pls.
how about denon 1612 and energy takes 5.0 speakers?
caloyzki is offline
post #17 of 23 Old 02-07-2013, 05:33 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Never heard HSU bookshelves personally but I've heard many rave about them and no one trash them so far:
http://www.hsuresearch.com/products/hb-1.html
I've seen these recommended a lot too:
http://www.theaudioinsider.com/product_info.php?p=arx-a2-center-lcr-loudspeaker&products_id=66&
Both of those links at least allow you to build a matching set over time. I won't lie I don't know the best speakers for the money in this range. I have a pair of Energy CB-10s which are 200/pr.
I would make a new thread to ask for suggestions of bookshelves in the $300-400 range if this idea interests you.
Denon 1612 isn't the only $200 receiver btw.
skidawgz is offline
post #18 of 23 Old 02-07-2013, 07:15 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would aim for bigger speakers - and build around them
Like the Cambridge S30
http://www.crutchfield.com/p_779S30N/Cambridge-Audio-S30-Noir.html
HTD Level Three or Level Two
http://www.htd.com/Products/level-three-speakers/Level-THREE-Bookshelf-Speakers
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
HSU bookshelf
Pioneer bookshelf
Who AM I
post #19 of 23 Old 02-07-2013, 07:33 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Where did you listen to them at? Best Buy?
My neighbor owns the Pioneer speakers and, to me, they sound like speakers that cost considerably more. They pretty much have a cult following around here to with lots of positive reviews. You may have just listened to them in a poor room, or the receiver was not setup right.
ack_bk is offline
post #20 of 23 Old 02-07-2013, 07:34 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
HSU bookshelf
Pioneer bookshelf
All of them are really good choices, and I agree build around your system. Focus on the front three speakers and than add components like a subwoofer and surrounds as you get more budget.
OP it would also help to understand how big your room is and how far away do you sit from the speakers?
ack_bk is offline
post #21 of 23 Old 02-07-2013, 08:28 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
My living room is not that big. Im not sure maybe 20x50 not sure if that is right. Ok i just bought denon 1612 and takes 5. If i want to upgradw my three front speakers which one should i go? Budget is 300. Can i just use my 2 takes for my surround?
caloyzki is offline
post #22 of 23 Old 02-07-2013, 09:01 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
20' x 50' Not that big? smile.gif I beg to differ.
You already have Energy Take 5.0 system??? We should have been advising you on a subwoofer instead.
skidawgz is offline
post #23 of 23 Old 02-07-2013, 09:42 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
That id only my guess not really sure. Yes takes 5 just came today with dayton 1200 sub.
caloyzki is offline
Reply Speakers
