need help with Blu-ray audio with panasonic tv via toslink!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-07-2013, 02:59 PM - Thread Starter
gtgamewizard's Avatar
hi all,
i have a panasonic viera TX-L42ET5E, and the Audyssey lower east side speakers (wich are a 2.0 speaker set) and i connected them via toslink optical audio. now if there's normal audio playing i works great with amazing audio, but if i try to play a Blu-ray or somethink like that it gives a pop and no audio.
whats the problem and how can i fix this??
thx in advance gtgamewizard
gtgamewizard is offline
post #2 of 6 Old 02-07-2013, 03:22 PM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
You probably need to change your blu ray player to send a 2 channel PCM signal, not a bitstream Dolby Digital or DTS audio signal. Your speakers don't know what to do with that.
So change the settings on your blu ray player....
Afro GT
afrogt is offline
post #3 of 6 Old 02-07-2013, 03:38 PM - Thread Starter
i play the blueray film prom my usb stick thats in the tv, can i change this on my tv itself also?
post #4 of 6 Old 02-07-2013, 10:45 PM
afrogt's Avatar
Liked: 763
I have no idea, maybe somebody else can help you.
Afro GT
afrogt is offline
post #5 of 6 Old 02-07-2013, 11:18 PM
Knight Operator's Avatar
sure you can... just go to audio settings and change it to pcm. on either your BR player or TV. there may also be a setting for audio passthrough, just make sure its not set to "raw" set it to pcm/44khz
Knight Operator is offline
post #6 of 6 Old 02-07-2013, 11:25 PM
afrogt's Avatar
Liked: 763
He's not using a blu ray player, he's using a USB stick with a blu ray movie on it apparently....
Afro GT
afrogt is offline
Reply Speakers
