True Proper Front Left and Right speaker placement... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-08-2013, 08:51 PM - Thread Starter
Karl Thomas's Avatar
I have a 5.1 surround sound setup...
when placing front left and right speakers, do I place them according to MY left and right when facing the wall, or when my back is facing the wall?
Because when you go to read the back of the surround sound device it tells you what wire and corresponding speaker goes where, but if you're facing the same direction your system faces then wouldn't the right speaker be placed on its right side? also the same question for the back speakers
Karl Thomas is offline
post #2 of 3 Old 02-08-2013, 09:51 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
You're overthinking it. Think of it as from your listening position as to what is on your left and right...
lovinthehd is offline
post #3 of 3 Old 10-06-2013, 07:54 PM - Thread Starter
ok thank you very much for your help. i guess i was over-thinking it, but; was it a good question? lol
i did as you said and it worked great. terrific sound quality.
Reply Speakers
