Speaker wire - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2013, 12:56 PM - Thread Starter
Pat315's Avatar
Here's another stupid question about speaker wire. I getting new speaker I thought its a good time to upgrade the wire. The wire is about 15 years old and so is the banana plugs should I upgrade them?
Pat315 is offline
Old 02-09-2013, 01:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
The major source of degradation of speaker wire is stiffening of the insulation, which is really a cosmetics problem.
The bananna plugs free you from worrying about the wire oxidizing.
If it ain't broke, don't fix it.
arnyk is offline
Old 02-09-2013, 01:48 PM
Bill Fitzmaurice's Avatar
Liked: 4767
What is an 'upgrade' consist of? Unless your current cables are seriously undersized there's nothing to be gained.
Bill Fitzmaurice is online now
Old 02-09-2013, 06:28 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
psgcdn is offline
Old 02-09-2013, 06:47 PM
K Shep's Avatar
The folks who claim they hear an audible difference in speaker cable rate the % change extremely low, 3-5%. Those folks are presenting a subjective voice not based on blind tests. Please present a budget that you have set aside for the speaker wire. I purchase speaker cable based on looks, in one system white looks better my second system I use black. I chose to spend 2% of my budget for the black cable in that system and 1.6% in the other system. My black cables sound exactly the same as my white ones.
K Shep is offline
Old 02-09-2013, 10:41 PM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
I make my own speaker cables and make them look as cool as I want. There's a DIY speaker cable thread in this section, I learned a lot about making your own. The only tool I had to buy extra to get the job done was a cheap heat gun.
Monoprice 12awg cable, tech flex nylon sleeve (your choice in color and size), cable pants as an option (I've made cables with and without), and heat shrink tubing and of course your choice of termination; bananas, spades or bare wire.
A guy can get relative cheap speaker wire and make it look like very expensive cable, not only that, my cheap cable "sounds" like VERY expensive cable biggrin.gif
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Old 02-09-2013, 11:25 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Got pictures?
BB1111 is offline
Old 02-09-2013, 11:55 PM
carsfreak88's Avatar
Originally Posted by BB1111 View Post
Got pictures?
here is a picture of my diy wires for my system
carsfreak88 is offline
Old 02-10-2013, 04:27 AM - Thread Starter
Pat315's Avatar
Where did u get the nylon sleeve?
Pat315 is offline
Old 02-10-2013, 04:33 AM - Thread Starter
Pat315's Avatar
What size sleeve for 14g
Pat315 is offline
Old 02-10-2013, 07:25 AM
Liked: 4767
Don't lose track of the fact that all those cosmetic additions are just that, cosmetic, and have zero effect on the sound. Not that there's anything wrong with making your cables pretty, but ugly works just as well. I don't think all the contributors in that thread are aware of that.
Old 02-10-2013, 08:56 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Nice, but the amp must be sitting on the floor next to the speaker! wink.gif
(Probably for a center speaker within the same console as the amp, right?)
psgcdn is offline
Old 02-10-2013, 10:51 AM
K Shep's Avatar
Great job those look great!
K Shep is offline
Old 02-10-2013, 11:06 AM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
I got mine from ebay. If you go look at the "Have a look at these babies" in the speaker thread, you'll be able to see the work of others, find out specific sizing for your needs etc etc. Have fun.
Really? I thought that was my point. No, wait a minute, you're wrong bill. I took $60 per 100 ft roll of 12x4, slapped a cover on it with some heat shrink, stuck some banana plugs on the end and I completly changed the sound of the wire and yes, wait for it............it now sounds like $84,000. and that's only because it was my first project. My second will sound like $200,000 cable biggrin.gif
Set up:
Old 02-10-2013, 11:36 AM
zamboniman's Avatar
Don't forget some cable levitating stand bridge things... plenty to be gained..
Have they come up with a green marker for your CD edge equivalent for the music on my hard drive?
zamboniman is offline
Old 02-10-2013, 11:45 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Furryletters on eBay will have a good selection of popular sizes and colors. There are other vendors on eBay that have additional not-so-popular colors. You can go with either 1/4" or 3/8". 100 feet of 1/4" will cover about 70 feet of 14 gauge and 3/8" will cover slightly more than what you buy. Some folks like a " shorter weave " and use 1/4" if they use a patterned flex, like the Rattlesnake pattern. The size probably won't matter for a solid color weave.
The in-wall cable that Monoprice is fine but the conductors are covered in a sheath vs. covered in molded rubber. This can leave a twist pattern in the cable on the larger gauges from 14 to 10 and up. I buy my cable from KnuKoncepts. They have an eBay store and an internet-direct store as well. Their cables are molded rubber and are perfectly round and more flexible than sheathed cable.
This picture shows the sheathed 12 gauge on top and the molded 10 gauge on bottom. The twisting is not really noticeable if the TechFlex is left a little slack.
This photo shows the KnuKonceptz 10 gauge cut-away.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Old 02-10-2013, 11:59 AM
yes this wire was for the center channel
thank you
Old 02-10-2013, 12:18 PM
Liked: 4767
The sad fact is that you're right, only what the suckers who buy high priced cables don't realize is that an $84,000 cable sounds just like a $30 cable. rolleyes.gif
Old 02-10-2013, 02:48 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
Cables can and do have a certain sound signature to them..I have heard this...I just ordered a pair of anti cables from Paul Speltz and they should be here tomorrow.I am going to do an unboxing and review of them that I'll post in the speaker board...keep an eye out...smile.gif
Doing what I do best...LIVIN!
josh6113 is offline
Old 02-10-2013, 04:35 PM
Liked: 4767
Unless you conduct a properly controlled double-blind testing session, and then post repeatable verifiable measurements, don't bother. That is the only scientifically valid method of making comparisons, and this is the Audio Visual Science forum.
Old 02-10-2013, 05:11 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
My video review will just be for fun...not a critical test...and I would love to know if you believe in god...if you do Prove it...wink.gif...not everything in life has to have proof...its human nature to need to see in order to believe...wink.gif
josh6113 is offline
Old 02-10-2013, 05:58 PM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
I think there may be a "slight" difference here; to believe in God requires faith, faith is the substance of things not seen, the evidence of things hoped for.
I don't see where faith plays into how two different types of cable can change the sound when it's job is to carry current from the source to the output. A different speaker may produce a different sound, a cables job is to allow current to flow from one place to another.
I personally have faith in the work of the cross, I don't have faith that this cable or that will change the way my speaker sounds, sorry.
Set up:
Old 02-10-2013, 06:05 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
josh6113 is offline
Old 02-10-2013, 08:54 PM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
Really, because learning how to read english and having a post H.S. education leads me to understand that your statement "Cables can and do have a certain sound signature to them" and me saying speakers make the sound and cables just carry the current to them so they can, have no "point" connection at all, but instead an indifference.
Set up:
Old 02-10-2013, 09:13 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
Bashing doesn't effect me and if you want to say something to me send me a P.M....and I won't try to convince you...cables do have sonic differenses...BUT the differenses are often small and equipment dependant.
josh6113 is offline
Old 02-10-2013, 10:27 PM
DemonicLemming's Avatar
What's always struck me as funny is that, as expensive as the high-end cable market is, I've never once seen actual empirical measurements between one cable and the next. A cynical observation would note it's probably so said cable manufacturers don't have to try and explain away identical measurements between their cables and the original cables, and so the guy who just spent $7,500 on a power cable doesn't have to deal with active denial that he spent his money on something that imparted absolutely no measurable difference. The descriptive words for the expensive cables also tend to run the same, regardless of what it's for (headphones, speakers, interconnects, power, whatever) - they add "sparkle" or "airiness" or any of the group of words that can be bluntly summarized as "elf farts". Light, delicate, and musical.
If cables do make a difference, I think it's less than (or at the most, equal to) the components in the equipment make - after all, if cable which carries a current can change sound, then surely the differences in one manufacturer's batch of resistors or capacitors and a later would also cause a change in the sound? That never seems to come up, though.
I'd say buy whatever decent set of cables seems good to you - or for those unfortunately stuck with a wife whose aesthetic demands outweigh all else, whatever she likes.
DemonicLemming is offline
Old 02-10-2013, 10:36 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
Well said...and the price that these multi thousand dollar cables are rediculious. As for me the most I've ever spent on cable was 100 dollars but I started way at the cheap low end and as I moved up and tried all sorts of cable I notices differences through most of them.
josh6113 is offline
Old 02-11-2013, 07:00 AM
Liked: 4767
I have. There are three factors that determine cable performance: resistance, capacitance and inductance. That's it, anything and everything else that the cable mountebanks claim influences the result is pure unadulterated bunk.
Where resistance is concerned all cables of the same material and gauge will have exactly the same resistance.
Where exotic materials are concerned there's nothing to be gained. Silver, the most commonly used 'high end' conductor has 5% less resistance than copper. But to get the same results with copper as silver you simply use either 5% larger gauge, or 5% shorter length.
Capacitance and inductance are affected by the size and dielectric properties of the insulation. But more expensive insulations work no better than inexpensive insulations.
There are measurable differences in capacitance and inductance between different cables. But those differences are never related to price. Some of the lowest measured capacitance and inductance are found in the least expensive wire available, while some of the worst measured capacitance and inductance are found in the most expensive wire available.
As for what really counts, can you hear a difference, in blind testing even self-proclaimed Golden Ears have never been able to correctly identify cables by brand, price or performance with any higher degree of accuracy than pure chance. That's because even though differences can be measured the measuring gear has a degree of accuracy a few orders of magnitude higher than the human ear. When a cable is so poor that it's audible it's simply defective.
Old 02-11-2013, 07:22 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Yes, copper gets old and tired from all those electrons flowing through it. ;-)
Of course one irony is that since audio is AC, there is only negligible net flow of electrons. The same electrons have been shuttling back and forth for years!
Around here most of the power lines were put in the the 1950s and have been in place for over 60 years. I've noticed that power lines from the 1920s and 1930s often have their insulation falling off due to old age.
Oh and a hearty +1 to what Bill says in post #28.
arnyk is offline
Old 02-11-2013, 08:42 AM
smudge981's Avatar
Quoted: 51 Post(s)
Liked: 207
In high school science, we called the three properties of impedance the R.I.C. or "rice rule"...resistance, inductance, and capacitance...resistance being the main culprit. Keep it under 5% and you're fine. Oxygen-free copper, silver, Monster cables? Go for it if it makes you feel any better. Your money. Diminished returns, thy name is speaker wire.
"I am NOT suffering from insanity... I happen to be enjoying myself!"
smudge981 is offline
