Looking to upgrade from Boston Acoustic Micro 90x 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-10-2013, 10:09 AM - Thread Starter
gelly's Avatar
Im currently using a Marantz sr7005 coupled with a Adcom GFA 550 to drive my multi room. My main listening area is 17 x 20. Im looking to stay small with no towers. I feel my current Boston Acoustic is a little underwhelming. Especially my sub, which i can never seem get get quite right. Systems I'm considering are Gallo A'viva, Definitve Tech pro cinema 1000, Cambridge minx s325 and the Orb peoples choice. Im not opposed to building a system ,i really lie some of the HSU subs. I usually do about 65% watching TV/Movies and 35% for music. Any advice of which of these or any other system would be a substantial upgrade from my current set up would be greatly appreciated. Larry
gelly is offline
post #2 of 6 Old 02-10-2013, 10:14 AM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
You have really nice electronics so the speakers are limiting your quality sound.
are those little speakers as large as you're willing to go?
Of the speakers you listed I'd go with the Pro Cinema 1000.
Afro GT
afrogt is offline
post #3 of 6 Old 02-10-2013, 10:25 AM - Thread Starter
gelly's Avatar
Thanks. I can go a tad larger, but I want to stay bookshelf for fronts and surround. I limited with size for my center. My current is 6.5 x 12, which fits perfectly in my builtins. However with a little retrofitting I can go up to 6 x 24.
gelly is offline
post #4 of 6 Old 02-11-2013, 06:04 AM - Thread Starter
gelly's Avatar
Are there any other obvious choice i'm leaving out? I was also thinking building a ascend acoustic system. Not sure if the Sierra 1 is meant to be placed in a shelving unit?
gelly is offline
post #5 of 6 Old 02-11-2013, 10:35 AM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
The systems you have listed are "higher end" satellite systems that will struggle in your medium sized room, especially the subwoofer! Those says might be fine for rear surrounds....
Some smallish "real" bookshelves worth considering:
CA s30s with s50 center
Ascend acoust cmt170 and 340 center
HSU smallish bookshelfs
Subs to consider:
Klipsch 12 in
Hsu or svs ID subs!
Polk psw505
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #6 of 6 Old 02-11-2013, 11:30 AM - Thread Starter
gelly's Avatar
Thanks, With regards to the HSU or SVS subs, which model/size do you recommend? also is it essential the sub be facing you? I currently have my sub behind,in a corner of my listening area. Which surrounds make the most sense? or does it depend on what center and sides i go with ?
gelly is offline
Reply Speakers
