Newbie needs help on great room ht - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 02-10-2013, 02:57 PM - Thread Starter
Lakehouse's Avatar
I have a 15x30 great room with the tv mounted on the 15' wall. The sofa is a room separator placed 12' in front of tv, with the kitchen/dining room taking up the remaining 18' of space behind the couch. I don't have a good spot for rear speakers so I am only looking for fronts, center,sub
I have it narrowed down to the following:
Energy 5.1 Take classic(not using rears)
Or
Sp-fs51 or 52 plus a c21 or 22 with a good sub
Or
Rti a3 with their center(forgot the name/number) and a good sub
Thoughts???
As far as a sub, I'm thinking of a bic f12 or energy s10.3
Lakehouse is offline
post #2 of 21 Old 02-10-2013, 03:00 PM - Thread Starter
Lakehouse's Avatar
Also, with whatever your choice, can you please recommend a receiver (please be specific if possible) to accompany your choice. Thanks!
post #3 of 21 Old 02-10-2013, 03:09 PM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15904
what is your budget? and is this with the avr recommendation
i'm so laid back,i'm laid out
smasher50 is online now
post #4 of 21 Old 02-10-2013, 03:12 PM - Thread Starter
Lakehouse's Avatar
Would like to keep it under 600, prefer under 500. This does not include receiver. There is a set of the sp-fs51 on eBay for 125, or the fs52 on amazon for 125ea
post #5 of 21 Old 02-10-2013, 03:18 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Pioneer towers with matching or the Polk RTi A3's with a CSi A6 or CSi A4 center
Throw in Bic F12 and you will have a decent 3.1 speaker set
crazyrob425 is offline
post #6 of 21 Old 02-10-2013, 03:31 PM - Thread Starter
Lakehouse's Avatar
How about a receiver to push the polks?
post #7 of 21 Old 02-10-2013, 03:33 PM
Quoted: 443 Post(s)
Liked: 337
How much do you have for a receiver? Is that included in your $600 speaker budget?
post #8 of 21 Old 02-10-2013, 03:43 PM - Thread Starter
Lakehouse's Avatar
No, the 600 is for speakers only. Not sure on budget for receiver as I'm going to have to save for a month or so for that.
You think I will get the same "bang for my buck" with the Polk bookshelfs as I would the pioneer floor standings? I hope so, as the room would look better with the fronts hanging on the wall instead of on the floor
post #9 of 21 Old 02-10-2013, 03:58 PM - Thread Starter
Lakehouse's Avatar
Pioneer setup will cost 330.00 plus 187.00 for f12 sub for a total of 517.00
Polk setup will cost 500 plus 187.00 for f12 sub for a total of 687.00
Both are doable, but is the Polk that much better to warrant the extra money? Seems the biggest cost difference lies in the center channel (80.00 for pioneer and 200.00 for Polk)
post #10 of 21 Old 02-10-2013, 04:43 PM
Quoted: 443 Post(s)
Liked: 337
I personally not a fan of the pioneers, which is why I have the Polks. The Poineers sound pretty dull and muted to me.
Some receiver to look at are the Denon AVR-1613 ($400) Onkyo TX-NR616
post #11 of 21 Old 02-10-2013, 04:56 PM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15904
fwiw with that size room and budget you might also option to go with a 2.1 system for example pair the boston acoustics a360's at accessories4less $360 . these are a great bargin for their price ( white with black grills , imo look nice)) and a better sub like the klipsch rw-12d $300 on newegg. this in my opinion would give you better sound quality overall. then save up for the boston acoustics a225c center $150 at accessoriess4less.as for an avr look also at accessories4less they are an authorized dealer and have some nice bargins on manuf. refurbs in all price ranges and needs. my recommendation would be the denon avr1612 $200
post #12 of 21 Old 02-10-2013, 05:07 PM
Elihawk's Avatar
Quoted: 1037 Post(s)
Liked: 874
Another option would be a pair of Def Tech SM 450s (300/pr) and the Klipsch 12 inch sub(300).
I own the def tech and they are outstanding speaker at that price. Drawback...if you decide later you want the def tech center later, it is expensive and hard to find!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #13 of 21 Old 02-10-2013, 06:24 PM - Thread Starter
Lakehouse's Avatar
Thanks guys. I think I'm going to go with the bookshelf instead of floorstanding. Does it make a difference wether I put them on stands or if I mount them on the wall (if on wall, they would have to be up high near ceiling and angled down towards couch)
post #14 of 21 Old 02-10-2013, 07:22 PM
Elihawk's Avatar
Liked: 874
If you are going to flush wall mount, you will need to make the speakers you by are not rear ported! The def tech I recommended are sealed, so these could be wall mounted!
Elihawk is offline
post #15 of 21 Old 02-10-2013, 08:55 PM - Thread Starter
Lakehouse's Avatar
post #16 of 21 Old 02-10-2013, 08:59 PM - Thread Starter
Lakehouse's Avatar
He is a pic of the wall. My speaker placement options are to
1: mount on wall up high and angle down (on each side of fireplace)
2: set on speaker stands on each side of fireplace
3: set on fireplace (where candles and brass pot are) obviously this will put them even closer together than option 2
The tv will get hung about 6" higher than it currently is (angled down) so that the center channel can fit on the mantle right under tv
post #17 of 21 Old 02-11-2013, 05:32 PM - Thread Starter
Lakehouse's Avatar
What do you think of these 2?
Onkyo tx-nr709 for 400.00new/refurbished
Or
Onkyo tx-sr805 for 300.00used
post #18 of 21 Old 02-11-2013, 06:18 PM
Quoted: 443 Post(s)
Liked: 337
709 would be my choice
post #19 of 21 Old 02-11-2013, 06:37 PM - Thread Starter
Lakehouse's Avatar
Is the 709 and denon1613 (both 400.00) worth almost double the cost of the denon1612 if I don't plan on upgrading any of this equipment? If so, would you pick the 709 or 1613 to pair with my setup?
I want to be able to run my speakers at their full potential, so I'm happy to buy whichever avr will do this BUT I don't want to spend extra money on an avr that won't gain me anything (sound wise) on my speaker setup in hopes that it will serve me well down the road if I upgrade speakers. This is a family room, not ht room, so I hope to set it up and leave it. (famous last words huh. Lol)
post #20 of 21 Old 02-11-2013, 06:53 PM
Quoted: 443 Post(s)
Liked: 337
Well the Denon 1613 has some more features over the 1612 like the 1613 has apple air play ability and it can be connected to a network, unlike the 1612. The Onkyo 709 can be connected to your network as well.
I know the 709 has upscaling so if you have a non-HD source it will upscale it to HD not sure if the 1613 has it I know the 1612 doesn't have it.
It all comes down to the features you want.
If you got $400 to spend I like the 709. If you only got $200 go with something less
Lakehouse likes this.
post #21 of 21 Old 02-11-2013, 09:18 PM - Thread Starter
Lakehouse's Avatar
Jumped on the 709 for 400.00
Thanks again for your help :-)
Reply Speakers
