Subwoofer placement? (Awesome paint picture included! lol) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-10-2013, 04:12 PM - Thread Starter
zowzout123's Avatar
So this is what I whipped up real quick for show purposes on placement of my subwoofer. I am just trying to find out where the best place to put it would be really. Any help or input would be greatly appreciated. The couch is movable and the picture obviously isnt to scale. The home theater setup isnt really movable and im having a hard time finding out where to place my floor standing speakers because they are uneven. I thought about the opposite wall, but our couch is 101"s and too large.
TLDR;
1) Best subwoofer placement
2) Optimal home theater setup and help with floor standing speakers?
zowzout123 is offline
post #2 of 7 Old 02-10-2013, 04:55 PM - Thread Starter
zowzout123's Avatar
post #3 of 7 Old 02-10-2013, 07:57 PM - Thread Starter
zowzout123's Avatar
Figured there would be something by now =/
post #4 of 7 Old 02-10-2013, 08:06 PM
cyde01's Avatar
I would start behind the left main speaker and near the sofa corner placed. Move it around and see where it sounds best to you.
cyde01 is offline
post #5 of 7 Old 02-10-2013, 08:06 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Nvm. Can you fit the sub next to the couch on the left?
GaryWA is offline
post #6 of 7 Old 02-10-2013, 08:18 PM - Thread Starter
zowzout123's Avatar
Yah it should fit back there no problem. But I would just have to run a long cable back to it (Which is fine). I just wasnt sure if the sub being that close to the couch was preferred or not.
post #7 of 7 Old 02-10-2013, 09:01 PM
GaryWA's Avatar
Quoted: 16 Post(s)
It's going to be the best you can do with that setup.
GaryWA is offline
Reply Speakers
Subwoofer Placement
