Thinking about getting a different set of PC speakers... but should I even bother? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-11-2013, 08:26 AM - Thread Starter
TheGrumpyCat's Avatar
Quoted: 12 Post(s)
Well currently I have a Altec Lansing ADA995 5.1 speaker set, THX certified, and it has 200 watts I believe. I kind of want to keep this since I bought it for just $10 at a yard sale and the sound quality is excellent, however I'm thinking about getting a 5.1 or 2.1 speaker set that has better sound, and also has a small subwoofer. The sub for the ADA995 is pretty much the same size as a desktop PC. Are there any PC speakers really worth upgrading to that are less than $130? Or should I just keep what I have? Currently I have my eyes on the Klipsch Promedia 2.1 speaker set or a Swan M10 2.1 set. I am using my speakers for my Macbook and PS3.
http://www.amazon.com/Altec-Lansing-Speaker-Subwoofer-Certified/dp/B0010AP3VK
http://www.amazon.com/Klipsch-ProMedia-Certified-Computer-Speaker/dp/B000062VUO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1360596268&sr=1-1&keywords=klipsch+promedia+2.1
http://www.theaudioinsider.com/product_info.php?products_id=89
TheGrumpyCat is offline
post #2 of 5 Old 02-11-2013, 10:54 AM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
I use the Audioengine 2 speakers for my PC, and they are great, but $199.
The M-Audio AV40 are $140, and might be good.
You could probably use your existing sub, since the volume is not going to be excessive when you are close; or you could get a used 10-inch one cheap.
commsysman is offline
post #3 of 5 Old 02-11-2013, 03:23 PM - Thread Starter
Quoted: 12 Post(s)
How would I be able to use the sub I already have? $140 plus buying a sub sounds a little too much for me.
post #4 of 5 Old 02-11-2013, 03:30 PM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
I misread; I thought you already HAD a subwoofer. my error.
The M-audio AV40 do have larger speakers than mine, so maybe no sub would be needed.
That's a matter of taste.
post #5 of 5 Old 02-12-2013, 02:22 PM - Thread Starter
Quoted: 12 Post(s)
bump
Reply Speakers
