7.1 Speakers for new dedicated home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-11-2013, 11:01 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Ok, I have been finishing out half of my second floor and we just finished the framing. We are doing electrical for the next two weeks and then will be ready for hvac and our rough-in inspection. In short I am seeing progress.
Here's where I need your help. I plan on having seating for up to 12 in a room that will be 18.5'x30'. I will have an acoustically transparent projector screen in the front of the room mounted to a false wall made of essentially grille cloth. I need LCR recommendations as well as side channels and rear in ceiling speakers as my layout will prevent the dipole rears I hoped to use.
Thanks in advance for the help!
Chris
wraunch is offline
post #2 of 13 Old 02-11-2013, 11:08 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
Well, since speakers can cost anywhere from a few hundred to a few hundred thousand dollars, a budget will be required. How much do you want to spend?
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #3 of 13 Old 02-11-2013, 11:17 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Good point. To give you an idea I will be pairing the speakers with an Elemental Designs a2-300 and one other (TBD) sub. I don't plan on spending $1000 per speaker and to be honest the LCRs can be ugly as hell as they won't be seen but they need to sound great! I like well defined sound with nothing too boomy as this is on my second floor above my living room. I really haven't set a budget for this but just to give you an idea I will probably hook it all up to an Integra AVR that will be a little under $1000 and I won't be using a separate amp in the beginning unless it's absolutely necessary but I will add one or two over time.
wraunch is offline
post #4 of 13 Old 02-11-2013, 11:21 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Since this is a large theater space and you won't have discrete amplification, I would take a look at the Klipsch Reference series. Their higher sensitivity gives you the theater dynamics even in a big space.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 13 Old 02-11-2013, 11:26 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Will do. Any others? Where are you in NC? I'm in Clayton near Raleigh.
wraunch is offline
post #6 of 13 Old 02-11-2013, 11:36 AM
Mike Garrett's Avatar
Quoted: 5562 Post(s)
Liked: 3542
mjgarrett100@gmail.com
Mike Garrett is offline
post #7 of 13 Old 02-11-2013, 11:39 AM
Elihawk's Avatar
Liked: 856
Ascend acoust cmt340 front stage. My friend ray has them in a old farm house with 12 foot ceilings (room alittle smaller than yours)and they do not struggle. Really nice speaker...
Elihawk is offline
post #8 of 13 Old 02-11-2013, 12:06 PM
Liked: 1319
Moving to Raleigh in 2 weeks actually, currently in Greensboro.
post #9 of 13 Old 02-11-2013, 12:15 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Never heard of Ascend but they seem to be good quality from a quick Google search.
wraunch is offline
post #10 of 13 Old 02-11-2013, 12:27 PM
Liked: 1319
Might actually be a good choice, their cabinets are nothing special but everyone that hears them says they are fantastic. I believe you can also demo their speakers.
post #11 of 13 Old 02-11-2013, 12:30 PM
Elihawk's Avatar
Liked: 856
I think they have a 30 day return policy, no questions asked...however, you pay the return shipping?
Elihawk is offline
post #12 of 13 Old 02-11-2013, 01:50 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I'm very intrigued. Tough to beat that price point!
wraunch is offline
post #13 of 13 Old 02-12-2013, 11:17 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Anyone know about the Klipsch Icon W line?
http://www.klipsch.com/icon-w-speakers
Are they high quality? I might be able to get the WF-35 and the matching surrounds and center for a great price.
wraunch is offline
Reply Speakers
