Looking for TV/Blu-Ray Sound - Can't go 5.1 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 02-27-2013, 02:15 PM - Thread Starter
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Okay, I found the crossover setting on my receiver. The Denon book recommends setting 80, but for small speakers to go higher. I put it at 90, it was preset at 40. Any issues with this do you think, or should I roll it back to 80?
Sounds MUCH better playing stereo music through my cable box.
Gaming hard from October thru April.
Samsung 60KS8000
Xbox One S
PS4 Pro
Astro A50s (2nd Gen)
s1njin is offline
post #62 of 65 Old 02-27-2013, 03:23 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Your Cambridge speakers should have no problem crossing over at 80hz if you want try setting it lower. Whatever sounds best to you smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #63 of 65 Old 02-27-2013, 04:12 PM - Thread Starter
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
They sound fantastic at 80. What would I get out of everything by setting it even lower? Would I get more bass going to the sub and less going to the Cambridges? I apologize for the newbie question, but I've never played around with crossover stuff w/ any of my gear.
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
post #64 of 65 Old 02-27-2013, 04:24 PM
cel4145's Avatar
Liked: 3002
I believe that Cambridge only rates the S50 down to 80hz, so probably best not to go lower than that. The S30s are rated down to 55hz and so could probably work OK with a 60hz crossover. Basically, set it lower if it sounds better to you. A lot of people go for 80hz because (a) that passes off much of the low frequency work from the receiver to the sub amplifier (takes a little load off the receiver) and (b) no higher than 80hz because the sounds coming from the sub are more likely to become localizable. Still, whatever sounds best to you.
But don't to below the crossover settings that your receiver/Audyssey came up with initially. Below that, Audyssey won't set any filters for your speakers to improve the response.
cel4145 is offline
post #65 of 65 Old 02-27-2013, 04:34 PM - Thread Starter
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Audyssey set up the crossover at 40 !!! That's probably why I wasn't hearing anything for regular stereo sound. I haven't tried this setup yet with true 5.1 sound. So .... did I screw something up? By lower I'm guessing you're saying if Audyssey set my speakers at 40, don't try for 20. Right?
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
Reply Speakers
