Klipsch Quintet IV vs Polk TL150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2013, 02:45 PM - Thread Starter
miacane86's Avatar
Recently purchased Quintet IV's on clearance at Best Buy for around $140, but noticed the Polk TL150 set just come up for 180 (3 days later). Is there a difference/worth upgrading? I'm putting together a new (BUDGET) home theater system, the receiver for which is on the way (a Yamaha RX-V373 - didn't need airplay and can upgrade to discrete later on/as money permits).
I don't want to do bookshelf speakers in the current setup, though I realize satellites aren't as good. It's a visual/setup thing in my current studio apartment. The Quintet center is a little too tall to fit in my media centers unit directly under the tv (the center shelf), while the TL150's center is supposedly 1" shorter, so may fit. I've purchased the TL150 and they're holding it for a week, after which I get full refund. So... thoughts?
Also, any recommendations on a budget sub would be appreciated. I really need to keep it under $100. The PSW-10 is on sale for $99.99 through Amazon, and has good reviews. Thanks!
miacane86 is offline
post #2 of 4 Old 02-12-2013, 03:12 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Keep the Quintet's and get yourself a psw10. The $40 extra on the TL150's will not even get you a $40 improvement so hold on to your money
crazyrob425 is offline
post #3 of 4 Old 02-12-2013, 03:14 PM - Thread Starter
miacane86's Avatar
Great. I'll just build a shelf to elevate the tv a few inches so I can put the Quintet center in front of it without it looking too awkward. Thanks for the advice!
Just to verify (and I'm terrible at this wattage stuff) - my V373 won't have any problems with powering the Quintets?
post #4 of 4 Old 02-12-2013, 06:47 PM
Quoted: 443 Post(s)
Liked: 337
there will be no issues with the v373
miacane86 likes this.
Reply Speakers
