Running speaker wire help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-12-2013, 08:40 PM - Thread Starter
cbo0485's Avatar
Hey, just starting my home theater and have a few questions.
I am adding a home theater to an existing finished basement, so it's making it a bit harder to run the wire like I wanted.
First right under my screen is a power outlet, so there is an electrical line running down the wall, just off center of my screen behind the wall. I am going to buy 12 gauge cl2 speaker wire, and am wondering how close can the speaker wire run to the electrical wire. Because the center channel of the speaker would be just to the left of the stud that the electrical wire is held. It'll be maybe 7-8 inches from the wire for a few feet and then 15 inches for 5 feet or so. Then when it comes through the top of the frame another electrical wire will cross it at a 90 degree angle.
Do I need to worry about interference?
If u look in the picture, the speaker wire will come up right there by the electrical.
Then it'll run above all the joists and ill staple it to every other joist there.
See any issues with either of this situations?
cbo0485 is offline
post #2 of 9 Old 02-12-2013, 10:11 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
You should be OK as long as you aren't running parallel to the power conduit. I would still try to be at least 6 inches away from the power conduit when crossing over/under it.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is online now
post #3 of 9 Old 02-13-2013, 07:19 AM - Thread Starter
cbo0485's Avatar
Unfortunately I don't think I can be 6 inches away. I can't run the wires horizontal, b/c that'd require taking the drywall down to drill holes in the studs. Going vertical, I can only come through that board that already has the electric running over it. Right behind that 2x4 the electrical is running, is cement block.
Is there anything I can buy to shield the cable from the electrical for a few inches? Like a sleeve I can run over the speaker wire, or a piece of metal between the two?
cbo0485 is offline
post #4 of 9 Old 02-13-2013, 08:50 AM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Does anyone know if monoprices specific "in wall" speaker wire would help him? I would imagine crossing 120v is quite common. I know the extra casing is designed for code requirements not necessarily interference.
jvh4 is offline
post #5 of 9 Old 02-13-2013, 10:19 AM - Thread Starter
cbo0485 is offline
post #6 of 9 Old 02-13-2013, 10:26 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I have never really worried about interference much myself, but why not run the monoprice wire through metal casing where it matters?
psgcdn is offline
post #7 of 9 Old 02-13-2013, 10:30 AM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2817&seq=1&format=2
That's what i was planning on buying, 200 ft of it
Nice. What I was hoping someone could weigh in on was if this would help.
The extra sheathing is for insulation for code purposes, not shielding for interference purposes. What I am speculating is that interference should be subject to resistance and the extra sheathing is resistance. I just don't know real world what it all boils down to.
If there a way to DIY shield that mono price wire, maybe a grounded wrap of some type? I don't know how that would impact the code compliance though.
jvh4 is offline
post #8 of 9 Old 02-13-2013, 10:44 AM
Bill Fitzmaurice's Avatar
Liked: 4630
Speaker cables are quite immune to RFI and EMI, so you don't need to go to great lengths to separate speaker cables from AC lines.
Bill Fitzmaurice is offline
post #9 of 9 Old 02-13-2013, 11:11 AM - Thread Starter
cbo0485's Avatar
Good idea, hadn't thought of that yet. I should just need a few feet of that, and I'll run that just where it's going to intersect the electrical lines.
cbo0485 is offline
Reply Speakers
