SO...narrowed down to Klipsch and PSB. Now which one? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2013, 12:50 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Some would say you get most of the benefits from the HSU of a horn loaded speaker with not as many negatives. Just listing options.
On the other hand, I agree with the point everyone is making... You *seem* to like the bright and dynamic sound of a metal based tweeter and a soft dome tweeter may not be to your liking. (Note: bright and dynamic are the nice terms ...other people refer to this using other terms wink.gif )
Newbie01 is offline
Old 03-02-2013, 02:08 PM - Thread Starter
border411's Avatar
My friend has HSU speakers...and I love them...but they dont have a center channel (or any speaker that I could use as a center channel) that will fit with my space requirements. I will check out Paradigm.....any thoughts on model? And yes...I do like "bright" sounding speakers. Kidna worried that my Yamaha receiver (which has a rep of making things sound "brighter") might making the Klipsch TOO bright.
~Shaun
Yamaha RX-V765 / PSB B5's Fronts / PSB C4 Center / Micca R-65 In-Ceiling Rears / BIC F12 Sub
border411 is offline
Old 03-02-2013, 02:26 PM - Thread Starter
border411's Avatar
Just looked at the specs of the smallest matching center for the monitor series....too big.
Also....I love BIC, but the center for their horn loader speakers are too big as well.
~Shaun
Old 03-02-2013, 04:54 PM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
I would figure out a way to make the center work instead of passing on some great speakers.
Licence to Kill
Bond 007 is offline
Old 03-02-2013, 07:48 PM - Thread Starter
border411's Avatar
It wont fit on the mantel if it is that large (not enough room between the mantel and the TV).
This is also just my den, and dont need huge speakers floating around. Trying to get descent sound from small-ish speakers. The dedicated HT will be coming in a few years down in the basement.
~Shaun
Old 03-02-2013, 07:59 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
I had a thx Yamaha receiver paired w my ref klipsch and while I liked my denon better the Yammy didnt make them any brighter than normal. Also klipsch centers are huge...fyi
Brian Fineberg is offline
Old 03-02-2013, 08:02 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Are you willing to mount the center over the TV? Like Bond said, I'd go that before passing up on good speaker options. I think tiny centers are a huge compromise, too.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 03-02-2013, 08:12 PM
Bond 007's Avatar
Liked: 1911
Sounds like you have thought it out pretty well and already made up your mind. So back to the original question.I would go with the Klipsch.
Licence to Kill
Bond 007 is offline
Old 03-02-2013, 08:43 PM
Browninggold's Avatar
Liked: 37
My vote is for Klipsch...I've owned JBL, Bose not the Cubes and Aperion.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Old 03-03-2013, 05:35 AM - Thread Starter
border411's Avatar
Actually...the Rc42 is a perfect size, however I was actually thinking trying to get my hands on another RB51 and using that one its side for a center.
~Shaun
Old 03-03-2013, 12:36 PM
you2slo's Avatar
An RB-51 on its side is not ideal. Keep in mind it has a 90*x60* horn. The horn will be on the incorrect axis if you lay it down. At that point, the RC-42 would be the better buy.
you2slo is offline
Old 03-03-2013, 06:13 PM - Thread Starter
border411's Avatar
I was thinking that.....but I was wondering if I could turn the tweeter like in most speakers for the correct orientaton if it was on its side.
~Shaun
Old 03-03-2013, 07:43 PM
Liked: 37
This info is what started my interest in matching my 3 front. I sold my horizontal center and purchased another RF7II...seamless front stage. If you can I would fit 3 bookshelfs across the front if you can. I ceiling mounted my 55" so I could put 3 Klipsch RF7IIs across the front.
http://forum.blu-ray.com/showthread.php?t=89614
