Help me finish my setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-13-2013, 09:20 PM - Thread Starter
chadsherk's Avatar
Quoted: 13 Post(s)
Hello all,
I need some advice regarding a center channel speaker. I am installing a 5.1 home theater system in our family room. The room is a new addition to our house. When it was being built, I roughed in 4 Polk Audio rc-85i in-wall speakers for my surrounds. I have a Denon 1613 AVR and an infinity PSW310BK sub, so now it is time to add the last piece. I need a relatively low profile speaker, and If like to keep it under $300 if possible. A couple I've looked at are the Polk Audio TL3, and the Definitive Pro Center 1000. Anyway, given my setup, what would you recommend? Many thanks to you all in advance!
chadsherk is offline
post #2 of 3 Old 02-13-2013, 10:04 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2995
Your front three speakers should timbre match for the best front soundstage. This typically means buying from the same manufacturer and often even the same speaker line for your center. You might contact Polk to see which of their center channels in their other speaker lines would be the best match
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 3 Old 02-14-2013, 05:24 AM
MalVeauX's Avatar
Originally Posted by chadsherk View Post
Hello all,
Heya,
Matching line/drivers would give you optimal results. The RC series by Polk doesn't include big standing speakers. Maybe take some RC80i's and mount them in a small speaker box and finish the box to match whatever decor.
Very best,
Source: Pioneer VSX1121
Fronts: Polk Monitor 70 x 2 (AudioSource AMP100 in bridge mode, each)
Center: Polk Monitor 70 x 1 (AudioSource AMP100 in bridge mode)
Side Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Rear Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Subs: Polk PSW505 x 2
MalVeauX is offline
Reply Speakers
