Hi, I'm new and need some advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-14-2013, 05:12 PM - Thread Starter
FlyinPhotog's Avatar
Hello all. Long time lurker and now that I am a homeowner I am ready to start building a somewhat budget setup. This forum is the ultimate resource, thank you to all who contribute.
My room is 20x14.
I plan on going with an Epson 8350 with a 100" Jamestown screen.
I think for my uses (a 5.1 sys) I am going to go with the following speakers:
Monoprice 4101's for L and R
Monoprice 4881 for the center
Monoprice 4104's for the rears
I don't know what kind of receiver to get or sub so feel free to throw out opinions on those too.
Will this set up be enough for the room size? I have read most of the thread on monoprice speakers and this sounds like it should work just fine. Thanks!
FlyinPhotog is offline
post #2 of 4 Old 02-14-2013, 05:18 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
Sad that you spend so much on display and so little on audio. I suppose it's better than no sound at all.
shadyJ is offline
post #3 of 4 Old 02-14-2013, 05:22 PM - Thread Starter
I am not an audiophile by any means but I will take suggestions for something better instead of snarky comments. My budget for speakers is in the neighborhood of 500-1000 bucks.
post #4 of 4 Old 02-14-2013, 05:40 PM
Elihawk's Avatar
Quoted: 1323 Post(s)
Liked: 1157
So not counting a reciever, you have up to 1000 dollars to spend on speakers/sub? As a side, I agree with the above suggestion that your budget us out of whack... But it is your money.
Some suggestions;
Klipsch 12inch sub, 300 dollars
Ascend acoust cbm170 fronts (300/pr)
Matching cmt340 center (300)
Cheap surrounds or get them later!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
Reply Speakers
