Onkyo s9400thx and samsung led 60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-14-2013, 08:46 PM - Thread Starter
Anhikilator's Avatar
Hello all,
I have a Samsung 60 inch led lcd and the Onkyo s9400thx. I need two things. First a recommendation for towers for the 4 surround speakers and the I'd like to know what to do with my center speaker. Is there any stand that will attach to the TV and hold the center speaker there? If I put it on the TV Stand, the height of the speaker covers the TV. I can't make holes in the wall since I'm renting. Any other suggestions will be greatly appreciated.
M
Anhikilator is offline
post #2 of 3 Old 02-15-2013, 05:11 AM
flickhtguru's Avatar
Liked: 111
Probably a little late for this now. But here is the type of TV stand that I use. It is made by Z-Line Designs and is the Vitoria (Black) Stand.
http://www.bhphotovideo.com/c/product/711894-REG/Z_Line_ZL564_44MU_Vitoria_Flat_Panel_TV.html
It has 3 open glass shelves and a fancy post or support that goes up the back which allows the TV to hang from this stand just like it would hang on the wall. I have a 60" LG Plasma and I have my TV mounted at the highest location which isn't too high for viewing its just right for me PLUS I have a 10" high center speaker that can sit on the top shelf of the stand without blocking the TV.
Here is a pic of my setup so you can see.
http://i1264.photobucket.com/albums/jj489/flickhtguru/IMG_0280.jpg
Shawn
flickhtguru is offline
post #3 of 3 Old 02-18-2013, 10:09 PM - Thread Starter
Yeah that looks sweet but I've already bought a tv stand and don't want to change it. Thanks anyway. I don't know what I will do with my setup.
Reply Speakers
