In-wall / In ceiling speakers: Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-15-2013, 01:09 AM - Thread Starter
jboddu's Avatar
Hi All
I am currently in the process of rebuilding my home - currently done with framing and starting LV wiring. I have a couple of rooms where I am planning to install in-wall (LCR) and in-ceiling speakers ( Rear). A few questions:
In the great room ( FR + Kitchen), the room is approximately 32'x18'x10' We would like to use the room mostly for HT viewing (55" LCD) with most viewing at 14' . Planning a budget of $2.0K for 7 speakers ( LCR + 4 rear, I do have a nice subwoofer) but can go higher ( or lower).
Recommendations for LCR speakers where the grille's can be painted ?
jboddu is offline
post #2 of 6 Old 02-17-2013, 05:57 AM
Joshua Gessner's Avatar
for very clean and detailed sound i would go with martin logan you could do
3 MartinLogan ElectroMotion EM-IW 449.99 each =$1,347
http://www.martinlogan.com/architectural/electromotion/em-iw.php
4 Helos 10 Architectural Series
$299 each = $1,196
total = 2,543
These are such awesome speakers, with great detail!!
Joshua Gessner is offline
post #3 of 6 Old 02-17-2013, 06:07 AM
OR
3- CINEMA LCR1 The new Cinema LCR is designed to provide outstanding performance in a home theater system while maintaining a slim profile on the wall. The advanced custom-designed drivers, crossover and full MDF enclosure combine to reproduce wide dynamic range film soundtracks and music with startling clarity and realism. Cinema LCR is a symmetrical array, allowing it to be positioned vertically or horizontally without a compromise in performance.
http://www.sonance.com/products/speakers/detail/475
4-VISUAL PERFORMANCE® VP61R
http://www.sonance.com/products/speakers/detail/569
post #4 of 6 Old 02-17-2013, 06:27 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
My neighbors use Paridigm and I think they sound good and they are very happy. I think there the CS series. One actually painted his grills to blend with front wall.
http://www.paradigm.com/products/products-by-category/in-wall-in-ceiling
We use James Loudspeaker and love them.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #5 of 6 Old 02-17-2013, 06:42 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I would look for a speaker that is enclosed (v.s. an open baffle design). Especially if the room these are being installed in have room on the opposing walls.
http://www.cepro.com/article/how_to_prevent_audio_loss_with_in_wall_speaker_systems
I use these and am very happy:
http://www.definitivetech.com/products/uiw-rls-ii
The RLS III model is in your budget and you should be able to find them for under $400 shipped each.
Many other companies offer backer boxes as well. I would also look into Atlantic Technology, and Episode. You may have to stretch the budget a little for those other brands smile.gif
ack_bk is offline
post #6 of 6 Old 02-17-2013, 07:38 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
+1 on being enclosed box.
Control4
Reply Speakers
