Near field active computer speaker. $700 budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 02-15-2013, 09:33 AM - Thread Starter
jeffxx's Avatar
Hello all. I've been researching speakers for a few weeks now. I bought the Adam f7 and returned them because I would want a subwoofer to go with them and that exceeded my budget. I also don't necessarily want that clinical flat sound since these will be for listening only.
Could anyone please help me with this? I thought I found the perfect speaker (paradigm atom a2) but they suffer hissing problems. Any help would be great.
jeffxx is offline
post #2 of 28 Old 02-15-2013, 09:37 AM - Thread Starter
jeffxx's Avatar
Also, it must be front ported. Will be near a wall/corner. Sorry, I'd edit but I'm on my phone and new to this forum!
jeffxx is offline
post #3 of 28 Old 02-15-2013, 10:56 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I would say the Emotiva Airmotiv6, you could also look at Mackie, KRK, Genelec, and Behringer.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 28 Old 02-15-2013, 11:40 AM - Thread Starter
jeffxx's Avatar
My issues with those are the flat sound. Was more so looking for possible hifi speakers. If I want to hear details, I have headphones for that.
jeffxx is offline
post #5 of 28 Old 02-15-2013, 11:43 AM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
BB1111 is offline
post #6 of 28 Old 02-15-2013, 11:48 AM - Thread Starter
jeffxx's Avatar
It's not that crazy of a statement. Studio monitors are flat for a reason. I'm looking for a speaker that is more colorful and will not be as affected by the environment the speaker is in.
jeffxx is offline
post #7 of 28 Old 02-15-2013, 11:53 AM
Liked: 1319
Well the point of most active monitors is detail and accurate reproduction. You could take a look at the Swan M200MkIII, http://www.theaudioinsider.com/product_info.php?p=swan-m200mkiii-active-desktop-loudspeaker-system&products_id=121&osCsid=0117a6a81ad8a4595992736c3870e1aa They are very well liked and may have a more colored sound that you are looking for. For $700 though you could very easily buy the Emotiva mini-x a-100 amp and then spend $500 on a pair of bookshelf speakers. Then you have a lot more options, and can find something that fits the sound you are looking for.
post #8 of 28 Old 02-15-2013, 12:00 PM - Thread Starter
jeffxx's Avatar
Well maybe I'll try monitors again. Either the Adam f5 or the Behringer b3030a. Maybe the Pioneer sdj05. Any thoughts?
The swans are rear ported and I can't make room for them.
jeffxx is offline
post #9 of 28 Old 02-15-2013, 12:27 PM - Thread Starter
jeffxx's Avatar
If I plan to get a subwoofer in the future.. would it not make sense to get a speaker bigger than 5"? Would I be better off getting the Adam f5 instead of the 6.5" behringer?
jeffxx is offline
post #10 of 28 Old 02-15-2013, 01:45 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
If you plan on getting a subwoofer in the future, most likely you'll be configuring the crossover to where the speakers start to roll off. So your sub will be able to fill in the lower bass. I would think a 5" would be fine.
Consider what Transmaniacon said. If there are passive speakers you know you like, the Emotiva mini-x a-100 amp would work well. I run Energy V5.1s with an HK 3390 receiver. I would put my setup up against any pair of $500 power monitors. More colored sound, of course.
Also, what are you using for a source to run to the speakers? Motherboard audio that comes built in can be pretty meh.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 28 Old 02-15-2013, 01:49 PM - Thread Starter
jeffxx's Avatar
I have a decent dac as well as the asus stx sound card.
jeffxx is offline
post #12 of 28 Old 02-15-2013, 01:52 PM
cel4145's Avatar
Liked: 2985
cel4145 is offline
post #13 of 28 Old 02-15-2013, 01:54 PM - Thread Starter
jeffxx's Avatar
Problem with bookshelf speakers is that they might not be great for near field
jeffxx is offline
post #14 of 28 Old 02-15-2013, 02:17 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15603
fwiw,take a look at the paradigm shift a2 's $580 at crutchfield
i'm so laid back,i'm laid out
smasher50 is offline
post #15 of 28 Old 02-15-2013, 02:41 PM - Thread Starter
jeffxx's Avatar
I want to test those for sure. They have an audible hiss which might bother me in the near field however
jeffxx is offline
post #16 of 28 Old 02-15-2013, 05:26 PM
warpdrive's Avatar
Liked: 48
Also look at:
- KEF X300A
- PSB PS1
- Focal XS Book
The last two you would want a sub for sure. The X300A you might be able to get away without a sub (ok, maybe not, since you had the Adam's and you still wanted a sub)
I ended up with compact desktop DAC/Amp and passive speakers after trying a bunch of studio monitors.
http://s17.postimage.org/9k4h7hkbz/DSC_0271_1.jpg
http://s17.postimage.org/m05sez31r/DSC_0275_1.jpg
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #17 of 28 Old 02-16-2013, 07:28 AM
dkr919's Avatar
If you have DIY skills there's a project from speaker designer Jeff Bagby. He based it on the original BBC LS3/5a specification. There's a kit available from Meniscus for $354 and here's a link and a photo of a recent build on the PE forum.
http://meniscusaudio.com/continuum-pair-p-1324.html
http://techtalk.parts-express.com/showthread.php?233623-Continuum-s-with-split-personality-My-first-DIY-build&highlight=continuums
dkr919 is offline
post #18 of 28 Old 02-16-2013, 09:55 AM - Thread Starter
jeffxx's Avatar
If I was too go the passive route, which speakers would be good for close listening. I listen to 95% of my music while sitting at my desk.
jeffxx is offline
post #19 of 28 Old 02-16-2013, 10:10 AM
cel4145's Avatar
Liked: 2985
I would definitely avoid Klipsch passive speakers for nearfield use. Many people find their horns fatiguing.
Your best bet would be to go out and listen to some speakers locally and see what you like. Then post back, and people can make recommendations from there.
cel4145 is offline
post #20 of 28 Old 02-16-2013, 10:30 AM - Thread Starter
jeffxx's Avatar
I have nothing but guitar center and sam ash near me unfortunately.
On another note... I didn't know an amp that could power passive speakers could be had for a relatively low price. This makes me think the passive route might be better. Especially in the search for a warmer, more musical sounding setup.
jeffxx is offline
post #21 of 28 Old 02-16-2013, 12:01 PM
cel4145's Avatar
Liked: 2985
Yep. You can get good amplification for around $200 or so. I caught the HK 3390 when it was on sale for $225 about a year or so ago. It's a bit bigger, though. Here's a used one on ebay: http://www.ebay.com/itm/Harman-Kardon-HK3390-AM-FM-Stereo-Receiver-Black-/200895613171.
cel4145 is offline
post #22 of 28 Old 02-16-2013, 04:31 PM - Thread Starter
jeffxx's Avatar
Do I need that monster? Lol
jeffxx is offline
post #23 of 28 Old 02-16-2013, 06:52 PM - Thread Starter
jeffxx's Avatar
WELL. Funny story. Walked into best buy and there were the Audioengine A5+ for $300 open box. I figured I'd give them a try and return if I didn't like them. So far they aren't too bad. Not overly impressed so far but we'll see after a few days.
jeffxx is offline
post #24 of 28 Old 02-18-2013, 06:42 AM
Liked: 1319
If you are considering the passive route, that Emotiva mini amp is a fantastic choice. It offers Emotiva quality in a small package and all for ~$200.
Speaker brands you may look into for passive speakers: Ascend, Focal, Wharfedale, PSB, Axiom, and then there's always www.audiogon.com where you could probably find a great pair for $500. Just a thought.
post #25 of 28 Old 02-18-2013, 08:16 AM
adupree's Avatar
Check out the Equator Audio D5. They are awesome little guys. Front ported like you need. The are $300 right now, but are going up in price at the end of the month.
Ignorance is a choice
adupree is offline
post #26 of 28 Old 11-29-2015, 09:52 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Did you keep these? What do you think of them?
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
post #27 of 28 Old 11-29-2015, 10:00 PM
mdbrown's Avatar
Quoted: 193 Post(s)
Liked: 98
I would recommend Wavecrest HVL-1 or Chane A1rx-c.
Yamaha Aventage RX-A740
Martin Logan Motion 12 Mains
Martin Logan Motion 8 Center
Martin Logan Motion 2 Surrounds
SVS SB-1000 Subwoofer
Panasonic TC-P50X1
mdbrown is offline
post #28 of 28 Old 11-29-2015, 10:04 PM
witchdoctor's Avatar
Quoted: 754 Post(s)
Liked: 199
JBL LSR 305 or 308. They use XLR cables so you may need to get an adapter for RCA, very easy though.
witchdoctor is offline
Reply Speakers
