Is it okay setting my rear speakers and center to 100hz ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-16-2013, 08:56 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
My right rear speaker makes a sound like the mid range is blow or something during certain times during a movie. This only happens when setting my rear to 80hz. When i set them to 100hz,its all fine.
dazkyl is offline
post #2 of 8 Old 02-16-2013, 08:58 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Your welcome to set your speakers to what ever crossover you like and sound good to your ears.
What speakers do you have?
crazyrob425 is offline
post #3 of 8 Old 02-16-2013, 09:03 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
No, you're only permitted to set your speakers to 80Hz. Anything else is strictly against the rules. Unless you really want to set them to 100Hz, in which case go right ahead.
eljaycanuck is offline
post #4 of 8 Old 02-16-2013, 09:04 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
But my right rear speaker kinda distorts during some times in a movie.
This is my speaker setup , except for the fronts. Theyre the jamo s608.
http://www.fonet.co.za/catalog/images/s606hcs3.jpg
dazkyl is offline
post #5 of 8 Old 02-16-2013, 09:08 AM
Quoted: 443 Post(s)
Liked: 337
There could be an issue with your right rear sepaker.
Set the center and surrounds to 100hz if the problem goes away then
post #6 of 8 Old 02-16-2013, 09:10 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
He has the "jamo s608 5.0 along with JAMO SUB 250 and ONKYO TX308 avr". His room is "about 4.4m x 4.6m and opened from one side".
But whats really wrong with setting the rear and center to 100 hz ?
dazkyl is offline
post #7 of 8 Old 02-16-2013, 09:28 AM
Quoted: 443 Post(s)
Liked: 337
NOTHING IS WRONG!
If it sounds good to you than DO IT!!!!! You are the only person that matters. How you make your system sound good is for you to decide.
And if there are rules I ignore them cause I go with what sounds good or or works for me.
post #8 of 8 Old 02-16-2013, 09:47 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Switch your left and right surround speakers wiith each other and see if the problem follows the speaker. If so you know you have a bad speaker. If not then its something else.
But if setting at 100hz remedies the problem then do it.
Afro GT
afrogt is offline
Reply Speakers
