I´m lost - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-16-2013, 09:11 AM - Thread Starter
maranellofan's Avatar
Hi,
I'm in a big dilemma. My system consists of a receiver: Rotel Rsx-1057, front speakers: Sonus Faber Concertino, cd player: Audiolab cdq 8200 and subwoofer: Rel Quake.
The Audiolab is a fresh addition, and everything seemed fine. Ater sometime i now realise that something does not sound as expected. The sound is sometimes slightly metalic and somewhat compressed. Although the Audiolab is the most recent piece, I am in doubt about which part of the system to change: Should I add an integrated amplifier? Should i change to a more efficient speakers? Should i send the Audiolab away?
I'm lost!
maranellofan is offline
post #2 of 4 Old 02-16-2013, 12:03 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Originally Posted by maranellofan View Post
Hi,
I'm lost!
Don't be in so much of a hurry to blame the equipment just yet. What material are you listening to? Is everything set properly, and placed properly in the room? Is your room " live" ...lots of hard surfaces?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 4 Old 02-16-2013, 12:32 PM
Paraneer's Avatar
Quoted: 30 Post(s)
Liked: 85
I agree with Espo. You have a nice assortment of components so I would first question the source material and your listening room. Your SF's are not very efficient but you are using a subwoofer so the Rotel should have plenty of power for your speakers.
Most CD's do sound compressed. Your word metallic could also be construed as cold or clinical. Couple this with a highly reflective room full of hard surfaces, and this could be your problem. How are your speakers placed relative to the listening position? Speaker placement as absolutely critical for a great sounding system.
Finally you say your CD player is the most recent acquisition. What did you use for a source component before that? How did you like the sound of your system then? To your ears, was it better, worse, the same? Start asking yourself all of these questions first before you attempt wholesale changes to your equipment. Like I said - you got pretty good stuff right now. Good luck.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #4 of 4 Old 02-17-2013, 08:44 AM - Thread Starter
Guys, thanks a lot for your help. I listen to almost everything, from classical to jazz, from pop to rock, from easy listenning to alternative... and yes everything is set properly, but will do a revision.
My room is not bad at all, but i'm gonna consult an acoustic specialist about this. My previous source was a Marantz SA7001, and now everything sounds globally better, but i would say that the main issues that i dislike, are about the same. I made this change so i could use the "external dac feature" from the audiolab.
Regards.
Reply Speakers
