Upgrading L/C/R need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-16-2013, 08:27 PM - Thread Starter
SamGresham's Avatar
I have fairly large area 6500 ft^3 that I might replace my infinity primus in. Or put these in a smaller room 3400 ft^3. My budget would be around 1200 for all three. They are being powered by a denon 2112. Which I'll be upgrading in the next couple of months or so.
What I am currently looking at:
L/R: Kef q300
C: Kef q600
Shipped $949
L/R Focal 814v
C: Focal CC814v
Shipped $1215
Are there any other speakers I should be looking at that I am missing. I've heard the Kefs at a friends house in a much smaller room and I really liked the way the sounded.
SamGresham is offline
post #2 of 7 Old 02-16-2013, 08:58 PM
Darrin_R's Avatar
That is a larger room. Can you use a tower for the center? If so - 3 of these would be fantastic.
http://www.frys.com/product/7386304?site=sr:SEARCH:MAIN_RSLT_PG
I haven't listen to the Kef but considering the size of your room, you might want to consider Q500/Q200, Q700/Q200, or Q700,Q600.
I have heard the Focal's and they are very nice and that is a great price. The surrounds are pricey!
Good Luck.
Darrin_R is offline
post #3 of 7 Old 02-16-2013, 09:21 PM
justindo's Avatar
I own the Focals and think they're great speakers for the price. They're efficient too, so they should play pretty loud in a large room like yours. I haven't heard the KEFs.
justindo is offline
post #4 of 7 Old 02-16-2013, 09:31 PM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
Are you using a sub? Is your listening mostly HT/TV or do you also listen to a lot of music (2 channel stereo)?
If you're using a sub (or sub's) and listening primarily to HT/TV the Q300's will fill the room fine. It might be worth noting that a third Q300 as a center would give you an excellent, even front soundstage. (Another pair of Q300's is actually a bit cheaper than a Q600. And because it's a concentric speaker you can lay it on it's side if you need to for space reasons.)
If you listen to a lot of 2 channel stereo music I would agree that you should consider towers for LR fronts in a room that size.
I haven't heard the Focals but they get universally good reviews, and that special pricing on A4L is a rare deal.
sdg4vfx is offline
post #5 of 7 Old 02-16-2013, 09:42 PM - Thread Starter
SamGresham's Avatar
It's going to be half HT/music. I have two vtf-15's.
post #6 of 7 Old 02-16-2013, 09:56 PM
coresare's Avatar
Sorry for the dumb question. What's the difference between a center and a LCR? I understand the LCR will play both left center and right signals...but I believe I see people using LCR's as a center in combination with a front left / right main speakers?
coresare is offline
post #7 of 7 Old 02-18-2013, 05:21 AM
xFreshEntrailsX's Avatar
Quoted: 60 Post(s)
Liked: 392
I have a question regarding replacing my R/L and C speakers and figured this would be the place. I don't have anything high end. I bought the onkyo ht-s5400 package over a year ago and have been more than happy with it. However I have decided I want to upgrade my front speakers. Now being pretty noobish with this stuff still, I want to be sure what I'm going to do will work. Now I'm not spending money at all, but I am going to be getting the yamaha ns-c444 and a set of ns-333(brand new and basically free) to replace my R/L and center speakers that came with the package. But I want to use the current R/Lspeakers to be used as my R/Lsurrounds as they are bigger and louder. Is this something that is doable with this receiver? Thanks for any and all help.
P.S. My speaker orientation is 7.1 with my 6&7 as front highs. The only way my living room will allow.
Onkyo TX-NR929, QSC GX5, Polk Audio RtiA9's, CsiA6, F/XiA6's, RtiA3's,PSA xs30se, Xbox 360, PS3, hopper w/Sling, Samsung 55" LED, All controlled with a Harmony One
xFreshEntrailsX is offline
Reply Speakers
