M-1: Small or large? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-17-2013, 11:07 AM - Thread Starter
s0bc's Avatar
I'll make this simple, should the Bowers & Wilkins M-1 speakers be set to small or large? They are paired with a PV1D and driven by a Sony STR-DN1030.
s0bc is offline
post #2 of 3 Old 02-17-2013, 11:14 AM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
In any system with a subwoofer all speakers should be set to small - it just becomes a question of where to set the crossover...
...and for the M1 that should probably be somewhere in the 80 - 100Hz range.
rick240 is offline
post #3 of 3 Old 02-18-2013, 03:40 AM - Thread Starter
s0bc's Avatar
Ok, then I have some flickering with the crossover settings to do it seems.
s0bc is offline
Reply Speakers
