Crossover - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-17-2013, 06:25 PM - Thread Starter
Pat315's Avatar
Please can someone explain how a crossover works? If a speaker can go low as 40hz and you set your crossover for your sum to 80hz isn't there a gap between the 40 & 80?
Pat315 is offline
post #2 of 8 Old 02-17-2013, 06:31 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
When you set the speaker crossover to 80hz the frequencies below 80hz are sent to your subwoofer, or to the other speakers that have a lower crossover or are set to large without crossover
crazyrob425 is offline
post #3 of 8 Old 02-17-2013, 06:36 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
You are talking about the crossover in the AVR (same principles apply to a crossover in a speaker between a woofer and a tweeter)...
- the crossover contains two components, a high-pass filter and a low-pass filter; what gets through the high-pass filter goes to your speakers, what gets through the low-pass filter goes to your sub
- these filters will have a slope that define how the sound falls-off, typically 12db or 24db per octave (more knowledgeable folks will talk about 2nd order and 4th order slopes, way over my head)
- so if you st the crossover in your AVR to 80 Hz that means the two filters are set to 80Hz
- the point about the slopes is that the filters are not brick walls; so not only above 80Hz goes to the speakers, below it also goes, but the further below 80Hz the weaker it will be; if you had a 24db/octave slope then the signal at 40Hz would be reduced by 24db
- so at an 80Hz crossover, your sub will get pretty much everything below 40Hz, most between 40 and 80Hz, some between 80 and 120 and little above; your speakers will get pretty much everything above 120Hz, most between 80 and 120, some between 40 and 80, and pretty much nothing below
rick240 is offline
post #4 of 8 Old 02-17-2013, 11:24 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
here is a generic visual representation of what the crossover setting is doing.
LEAD Technologies Inc. V1.01
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #5 of 8 Old 02-18-2013, 03:44 AM - Thread Starter
Pat315's Avatar
That explains everything. Right
Pat315 is offline
post #6 of 8 Old 02-18-2013, 04:12 AM - Thread Starter
Pat315's Avatar
So if speaker will down to 40 why set avr to 80?
Pat315 is offline
post #7 of 8 Old 02-18-2013, 04:24 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
A proper sub should deliver frequencies below 80hz better then the speakers. Also, by crossing over to a sub wether 80 or whatever frequency you happend to be crossed, help relief the speaker so they dont have to work so hard. But some peolple like to run their speaker full range and cross lower, around 50hz.
RicardoJoa is offline
post #8 of 8 Old 02-18-2013, 05:18 AM - Thread Starter
Pat315's Avatar
Ok thanks I understand better now
Pat315 is offline
Reply Speakers
