HT front stage - Polk 65T or 75T with RW-12d sub - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 02-23-2013, 05:36 AM
nagoy's Avatar
I don't want to start a new thread for such a similar setup, I have a pair of 65T's, a 25C, and a PSW505 on there way, but I have no idea what to use for surrounds. The obvious choice, given this lineup, is adding a pair of 35B's for surrounds. Would those work well? Are there similarly priced ($150ish) "real" surround speakers (bi/dipole)?
I have settled on Denon for my receiver, either the 1713 or the 2113CI (but only if a hefty discount is still available will I actually consider the latter!). I already have my Epson 8350, my first projector, and I'm v excited!
OP, sorry if I have hijacked your thread frown.gif I can move it if necessary.
nagoy is offline
post #32 of 43 Old 02-23-2013, 09:13 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
For a pair there isn't one in that price range. you can find a pair of Polk FXi A3's on ebay open box for $300 a pair
Can't go wrong with either reciever. The 1713 is the barebones audiophiles on a budget dream with its price and Audyssey MuliEQ XT. the 2113 brings some more features to the table with slightly more power.
crazyrob425 is offline
post #33 of 43 Old 02-23-2013, 03:51 PM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Hi new here,
I just picked up a new onkyo tx-nr515 and am running Bose 501 v series with Polk r15s. I just order a Polk cs20 and figured I would upgrade the front speakers and then maybe rears. The room is pretty large with. 20' ceiling. On newegg the 65t are 139 at the moment. I'm not looking to spend much money on speakers right now because I just bought a new house but really want a decent stereo set. I have a aiwa 150rms subwoofer it is supinely loud so I probably won't be changing that for a while. Is 140. Good deal for the 65t and would that cs20 work out with in also what rears would recommend?
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #34 of 43 Old 02-23-2013, 04:00 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2991
Originally Posted by lemonslush View Post
Hi new here,
Move the Bose 501s to surround duty for the time being, save your money a little longer, and replace the Aiwa subwoofer. Is it the TS W150? If you have a big room like that with high ceilings, a better sub could make a good difference, and you are probably driving that sub very hard anyway (might not survive for long).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #35 of 43 Old 02-23-2013, 04:43 PM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
What would you recommend for a sub? And yes my good man it is a TS W150. Also, do you think the 65t are a good choice ?
post #36 of 43 Old 02-23-2013, 04:45 PM
nagoy's Avatar
Given the front 65T's / centre 25C speakers, would the 35B's work well as 5.1 surrounds (I think it'd be an imbalance to spend $300 on rears)? Any alternatives?
nagoy is offline
post #37 of 43 Old 02-23-2013, 04:55 PM
cel4145's Avatar
Liked: 2991
Sure. Get the 65Ts. That's a good deal for that price. Then do some research on the AVS subwoofer forum and figure out what would be the best sub for your size room and listening habits.
cel4145 is offline
post #38 of 43 Old 02-23-2013, 05:00 PM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Your the man, thanks for the advice
post #39 of 43 Old 02-24-2013, 07:44 AM
Quoted: 443 Post(s)
Liked: 337
Yes the Monitor 35b's would be the best and the cheapest option.
When you get more money you can always buy the FXi's for side surrounds and Monitor 35b's as rear surrounds. Get the Monitor 35b's on your budget you aren't really missing much
post #40 of 43 Old 02-24-2013, 10:04 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
How do the 35b's compare to the r15s? Is it worth switching over from the r15s to the 34bs?
post #41 of 43 Old 02-24-2013, 05:09 PM
Quoted: 443 Post(s)
Liked: 337
The Monitor 35b's are far superior to the R15's the R15s are cheapest speakers Polk makes and they are horrible in my opinion.
post #42 of 43 Old 02-25-2013, 12:26 AM
nagoy's Avatar
thx for that.
btw, the 35B's are on sale at Newegg this week ($110).
nagoy is offline
post #43 of 43 Old 02-25-2013, 06:41 AM - Thread Starter
tshepp's Avatar
Of course my sub came with the port loose so have to fix that tonight. I am hoping to wire everything up this evening and give it a test run. Only have the front 3.1 system and need to order some in-ceiling rears soon.
tshepp is offline
Reply Speakers
Klipsch Rw 12d 12 Subwoofer Each
