Question regarding speaker cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-18-2013, 05:30 AM - Thread Starter
Szeppelin75's Avatar
I have two outside speakers on my balcony and the speaker cable wasn't long enough, i didn't calculate the lenght so i had to buy extra cable and i put the two together using electrical tape. My question is Do you lose quality on the audio signal by doing this and if you do is it something you can hear? i really couldn't tell the difference because to me the speakers sound "allright".
Can someone give me their honest opinion, without turning this into another speaker wire debate?
Szeppelin75 is offline
post #2 of 12 Old 02-18-2013, 05:42 AM
JD in NJ's Avatar
Liked: 37
What you've done should work fine, but I would suggest using solder or at least wire nuts rather than electrical tape. That stuff is really meant to insulate. That being said, what you've done could last for years, so long as nobody trips over the wires or something.
JD in NJ is offline
post #3 of 12 Old 02-18-2013, 06:05 AM - Thread Starter
Yeah it has worked fine, i just wanted to hear anybody's input regarding sound quality loss or not.
post #4 of 12 Old 02-18-2013, 06:07 AM
JD in NJ's Avatar
Liked: 37
I would not expect any sound quality loss so long as the connections you've made are tightly twisted and held firmly.
JD in NJ is offline
post #5 of 12 Old 02-18-2013, 06:15 AM
Bill Fitzmaurice's Avatar
Liked: 5687
If there was a problem you'd have heard it.
Bill Fitzmaurice is offline
post #6 of 12 Old 02-18-2013, 06:21 AM - Thread Starter
Thanks guys, i will get me some wire nuts anyway.
post #7 of 12 Old 02-18-2013, 11:24 AM
All4fun's Avatar
Good plan. If the wire nuts are going to be in the weather I would RTV the open end to keep moisture out. (RTV aka silicone adhesive)
All4fun is offline
post #8 of 12 Old 02-18-2013, 12:01 PM
Liked: 5687
A better solution is to use dielectric grease, auto supply stores sell it to use in sparkplug boots. I use it on all my outdoor outlets and light sockets.
post #9 of 12 Old 02-18-2013, 01:09 PM
All4fun's Avatar
Why is dielectric grease better? (not challenging you, just trying to learn the "why" behind the assertion.)
Spark plug boots have the added design objective of on/off repetitive removal over time. That is not particularly a concern with this wire nut connection.
-A4F
All4fun is offline
post #10 of 12 Old 02-18-2013, 01:13 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
They sell wire nuts suitable for outdoor use.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #11 of 12 Old 02-18-2013, 01:15 PM
Liked: 5687
It weatherproofs without making the connection permanent. Not that it might ever matter, but you never know.
post #12 of 12 Old 02-18-2013, 01:25 PM
All4fun's Avatar
Many thanks.
-A4F
All4fun is offline
Reply Speakers
