Center Speaker: Margin Logan Motion 6 vs HTD Flat Panel Speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-18-2013, 12:26 PM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
I have a Marantz Slimline NR1603 and 4 ceiling speakers. My challenge has always been getting a proper center channel. I have to mount the center channel below my TV due to the way my room is set up. So no big clunky center speakers. With that in mind...
I currently have a Margin Logan Motion 6 speaker mounted up. It is quite small but produces decent sound. I have been itching to upgrade to something louder. The ML Motion 6 seems to get distorted sound above certain volumes and doesn't drive clear dialogue like I would like.
After researching I found the company, Home Theater Direct, and they seemed to have some pretty excellent reviews. Anyone with personal experience or suggestions? Help me pull the trigger!
I am currently looking at this speaker:
http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
Price seems a little low, but I have read the price shouldn't reflect on the quality on this particular SKU.
tormz is offline
post #2 of 16 Old 02-18-2013, 01:26 PM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
tormz is offline
post #3 of 16 Old 02-18-2013, 01:56 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
What are you using for the left and right front speakers? You should get a center that matched those.
David
crussader is offline
post #4 of 16 Old 02-18-2013, 01:59 PM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
2 8" ceiling speakers
rears are also 2 8" ceiling speakers
tormz is offline
post #5 of 16 Old 02-18-2013, 03:44 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I understand. But what brand are they?
You want at least the tweeter in your center to match the tweeter in the ceiling speaker to match as close as possible.
David
post #6 of 16 Old 02-18-2013, 03:51 PM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
Bose in-ceiling
tormz is offline
post #7 of 16 Old 02-18-2013, 04:27 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
How big is the room (WxLxH)?
David
post #8 of 16 Old 02-18-2013, 04:35 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
post #9 of 16 Old 02-19-2013, 08:06 AM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
The room is approx 24x14x9
tormz is offline
post #10 of 16 Old 02-19-2013, 08:36 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I think the biggest problem is that the MartinLogan is a 4 ohm speaker, and the receiver is having trouble keeping up with it. You probably need to go with an 8 ohm speaker. As to whether the HTD is a good speaker, I have no idea.
tormz likes this.
David
post #11 of 16 Old 02-19-2013, 08:59 AM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
Roger. Recommendations on an 8 ohm speaker? Those DT speakers above are a little thick. Need to stick to 4.5 depth or less.
tormz is offline
post #12 of 16 Old 02-19-2013, 09:07 AM
Nalow's Avatar
Quoted: 21 Post(s)
Love the sound of the HTD center speakers.
I've used their Level Two center, and it looks to use the same drivers as the one you linked. So I'd expect this one to at least sound similar.
Very clean sound. Dialogue was clear, effects were as they should be. HTD makes solid products.
tormz likes this.
Nalow is offline
post #13 of 16 Old 02-19-2013, 09:12 AM - Thread Starter
tormz's Avatar
Quoted: 16 Post(s)
Nalow: Thanks for the great feedback and experience!
tormz is offline
post #14 of 16 Old 02-04-2014, 10:09 AM
ZOOM ZOOM's Avatar
Quoted: 12 Post(s)
Liked: 25
I'm in the same situation as to looking for a better center channel speaker. I have Wharfedale 10.1 for the front L & R. I have read that to many people do not like the Warfedale center channel speaker so I am still using an older speaker from previous set ups. this is my first time hearing of HTD speakers. any comments from current owners would be great.
ZOOM ZOOM is offline
post #15 of 16 Old 02-04-2014, 10:32 AM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
The only way to ensure that you will get a timbre match is to buy the center from the same company and the same model as your L/R. If you L/R speakers are Bose in celings, then you should check with Bose to get the correct center.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #16 of 16 Old 02-04-2014, 11:23 AM
ZOOM ZOOM's Avatar
Quoted: 12 Post(s)
Liked: 25
Ok I get the timber match. you don't want a C note from a piano to give two different sounds, one type from the LR, and another from the center. And it's possible that I have had one too many Baileys, but I like my center channel to be richer in sound, to stand out as being "different" from the LR. It is the dialogue channel in my HT, not the dedicated music channel.
Reply Speakers
