I need cheap towers. Used ok. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-18-2013, 02:22 PM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
Hey guys I am looking for a pair of floor standing speakers. They will be used for music only. And as far as music type, I listen to everything besides country music.
Size doesn't really matter. My budget it 1000 max. Audiogon any other used sites are okay. I live in PA and there are not a lot of high end dealers in the area for me to find a set used or anything. What do you guys recommend?
shortyg83 is offline
post #2 of 13 Old 02-18-2013, 02:39 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15593
fwiw, take a look at the focal 814v's $800 at accessories4less
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 13 Old 02-18-2013, 02:47 PM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
Is that seller reputable I never used that site? I have been looking at the focal 714 used for 699 or the 716 for 899 used so this would be a good price.
post #4 of 13 Old 02-18-2013, 02:51 PM
CleatusCat's Avatar
+1. I don't think there could be a better set of speakers at that price point!
Xbox Live- RumRiverKiller
HT Room- Samsung 550 64" Plasma, Tivo XL, Marantz SR-14 EX , BP3000TLs, CLR3000, BP2002 sides, Logitech 700
Music Room- Samsung 650 46" LCD, Tivo, Pioneer VSX-1120K , Canton GLE 409s, small cheap sub, Logitech 650
Garage- Kenwood VR606, Original Large Avents
CleatusCat is offline
post #5 of 13 Old 02-18-2013, 03:00 PM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
what is normal retail on those? 1800?
post #6 of 13 Old 02-18-2013, 03:14 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15593
fwiw the focal 814v is the focal 716 in gloss black. accessories 4less is an authorized focal dealer and very reputable i have and many other avs members have bought from them. they retailed for $1800. music direct sells the 716 for $1500
post #7 of 13 Old 02-18-2013, 03:23 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Define "Cheap" ...what are your criteria.. No sub so you want a good amount of bass?
Newbie01 is offline
post #8 of 13 Old 02-18-2013, 03:30 PM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
I did define "Cheap" 1k to spend.
And I do have a sub if needed, but it will not always be used.
post #9 of 13 Old 02-18-2013, 03:36 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
So 1,000 to spend only on the front two speakers right? Don't need speaker wire, reciever, speaker stands, players etc...we are talking 1k for front two speakers? Just clarifying because there are allot in the 1k budget range but your choices become more limited at the 800 range...and severely limited in the 600 range.
Newbie01 is offline
post #10 of 13 Old 02-18-2013, 03:40 PM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
Yes only the speakers. The 1k is speakers strictly. Anything else that I do not have will be purchased separately. I have been doing research on the focals originally suggested and I am leaning towards them. I was considering the Swan Diva 6.2 speakers but now I am more into the focal.
post #11 of 13 Old 02-18-2013, 05:06 PM
mobeer4don's Avatar
Quoted: 121 Post(s)
Liked: 115
...wrong thread.....
mobeer4don is offline
post #12 of 13 Old 02-19-2013, 05:22 AM - Thread Starter
shortyg83's Avatar
Quoted: 938 Post(s)
Liked: 880
Anyone else have an opinion?
post #13 of 13 Old 02-19-2013, 05:39 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
LSI15 refurbs on Polks ebay store. $849 for the pair.
http://www.ebay.com/itm/PAIR-LSi15-LSi-15-CHERRY-Tower-Loudspeaker-Polk-Audio-/230629800429?pt=Speakers_Subwoofers&hash=item35b29b79ed
I don't need snobs to tell me how to think, thank you!
67jason is offline
Reply Speakers
