Will I hear a difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-18-2013, 03:26 PM - Thread Starter
Mr Dave's Avatar
I currently have Boston Acoustics MCS 100 5.1 speakers. Using a Denon ARV 591 receiver.I am interested in the Polk Audio TL1600's. No place around us to hear them in person. The reviews on the TL1600 are great. Will I hear a difference????
Dave
Mr Dave is offline
post #2 of 4 Old 02-18-2013, 03:41 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
They will probably sound different but not neccessarily any better. The Polks use slightly smaller speakers from the spec sheets i read (2 1/2" vs 3" in the Bostons) so they could easily sound worse. If you want to upgrade you could look into buying bookshelf speakers and towers seperately rather than going the home theater in a box route. With full towers or even decent bookshelf speakers you can take the stress off the subwoofer for the higher bass ranges and have a better sound overall.
Mik James is offline
post #3 of 4 Old 02-18-2013, 06:44 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
This is the best way to get an SQ upgrade. Move away from HTIB speakers.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 4 Old 02-18-2013, 07:33 PM
MalVeauX's Avatar
Dave
You'll hear something different. Doesn't mean it's going to be better though.
Move into full size speakers or quality loudspeakers or bookshelf speakers if you want a real upgrade. The tweeters they peddle in home theater in a box setups have one real driver, a mid-driver, that they label a `sub' woofer.
Very best,
Source: Pioneer VSX1121
Fronts: Polk Monitor 70 x 2 (AudioSource AMP100 in bridge mode, each)
Center: Polk Monitor 70 x 1 (AudioSource AMP100 in bridge mode)
Side Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Rear Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Subs: Polk PSW505 x 2
MalVeauX is offline
Reply Speakers
