adding vintage Jbl's to the mix - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What would you do
Put the JBL as the fronts and c300 as surround? 0 0%
Put The Peavey in the front and the c-300s as the surround 0 0%
.Put the c300s in the front JBL or Peavey in the surround. 0 0%
Buy C70's for the fronts 0 0%
Buy the V.62 Veritas as the fronts 0 0%
Voters: 0. You may not vote on this poll
post #1 of 1 Old 02-19-2013, 09:44 AM - Thread Starter
bob2194's Avatar
Hello everybody.
I need some help !!
Here's what I have I have the energy C-series set up C-300 tower C50 center and C50b-1 surround.
My sub is a pa 12sub. I also have an older pair of JBL 4212b control monitor that spec at
45 hz to 15k hz and a pair of Peavey criterion ll PA loundspeakersmade for clubs, with a sound spec of 70 hz to20khz the peaveys have a large horn tweater. I just bought a denon 2312 av receiver to replace a pioneer 1018 ah receiver.
The question is I really don't want to use the small bookshelf c50 surround speakers. I have tried both jbl's and peaveys as fronts. The Jbl has a better low, peaveys has a better high end. They both sound ok the jbl has a better punch, but I set it up as small so I think that dosn't matter muc, except when I play some good ole rock n roll. I have read that the fronts and center all should match.
Here are my options;
1.solution.(not sure which one for the rears, probably the jbl since it goes down lower. The sub, correct me if I am wrong utlizes the lfe signal and assists the fronts only with the bass. I would get some stands to raise the JBL's up a little. Maybe the peaveys would be better because the freq response is higher. I am not sure which way to go on that.
2.Put the peavy or jbl in the front and the c-300 in the surround, the only problem is The center speaker isn't gonna match the jbl or peavey, maybe buy a jbl center. Not sure which one to buy.
3 I do have a few dollars left for maybe 2 front speakers I saw the c70s at frys for 299 apeice, and Energy V6.2 floorstanding speaker 2.5-way Veritas Series floorstanding speaker for 299.00.at Vans. What would you all do? I am really not sure. Those speakers won't last long so Need to figure this is out quick. I also saw some polk 70's for 299.00 a peice at ebay. Too many decision too little time. Help!
I think maybe buying the c 70 or the v6.2 veritas is the way to go, but I am not sure which of those 2 sets of speakers to buy, or maybe someone has another choice.
Thank you for any input!
Robert Opdyke
bob2194 is offline
Reply Speakers
