Need Help Deciding On Surround System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-19-2013, 02:43 PM - Thread Starter
rdcross's Avatar
So i can get any MartinLogan or Definitive Technology for a really good price and need to know which one will be better for my surround sound system.
I thought i was going to get the definitive technology 8060's for the fronts, and center, and 8040's for the rear. But then i noticed i can get martinlogan for a great price and now don't really know what i want to do.
Please let me know what your thoughts are and why i should do one over the other with specific reasons. This will be used for a 5.1 5.2 or 7.2 system.
Thanks for all your advice and help ahead of time.
rdcross is offline
post #2 of 7 Old 02-19-2013, 04:43 PM
border411's Avatar
I have heard both...I am assuming the ML's are the Motion series? If they are, then I preferred the Martin Logans. I thought they just sounded fuller....but that is just my opinion. I wasnt impressed with the Def Techs
~Shaun
Yamaha RX-V765 / PSB B5's Fronts / PSB C4 Center / Micca R-65 In-Ceiling Rears / BIC F12 Sub
border411 is offline
post #3 of 7 Old 02-19-2013, 04:44 PM - Thread Starter
rdcross's Avatar
Yes motion 40's or the esl
rdcross is offline
post #4 of 7 Old 02-20-2013, 06:06 PM - Thread Starter
rdcross's Avatar
Anyone else???
rdcross is offline
post #5 of 7 Old 02-20-2013, 06:35 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
We are missing a ton of information if you want advice... Size of room, budget, Home Theater to Music Use * 50 / 50 or 75 / 25 *
Do you have a reciever...what do you have...is a new one in your budget.
Subwoofer?
Newbie01 is offline
post #6 of 7 Old 02-20-2013, 06:39 PM - Thread Starter
rdcross's Avatar
So the room is open concept 15x15 lets say 80 to 20 movies to music reviewer will be a Yamaha 2020 which will be $750 of my budget the speakers will be the rest if I did the 8060's I would run the subs in the speakers
rdcross is offline
post #7 of 7 Old 02-20-2013, 06:41 PM - Thread Starter
rdcross's Avatar
Budget won't matter because of the cost I will get speakers at let's just say its a great deal but in my price would be Martin Logan motion 40's def tech mythos st or 8060's or martinlogan esl
rdcross is offline
Reply Speakers
