Polk Audio Monitor60 Series II Floorstanding Loudspeaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-19-2013, 10:53 PM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
Is there a different between this one the one i actually own http://www.newegg.com/Product/Product.aspx?Item=N82E16882290017 and then this one http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206 i'm thinking about getting the second one since one of my drivers is going out in the older model just wanna make sure it match each other
ryu4000 is offline
post #2 of 4 Old 02-20-2013, 12:14 AM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
The difference is the front baffle is silver on the original series while the front baffle is black on the new ones.
The black looks better to me.
That's it.
Afro GT
afrogt is offline
post #3 of 4 Old 02-20-2013, 12:17 AM
afrogt's Avatar
Liked: 923
By the way the Monitor 60 series II has be replaced by the Monitor 65T
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290271
They moved the tweeter to the top of the speaker but otherwise it is essentially the same as the Monitor 60.
Afro GT
afrogt is offline
post #4 of 4 Old 02-20-2013, 12:30 AM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
wouldn't i have to buy two since the tweeter be at the top instead of like the old 60's?
Right now i use cs2 for center surrounds monitor 40 and front speaker is 60's but that one 60 needs to be replaced just wanna make sure it will still timber match.
ryu4000 is offline
Reply Speakers
