help... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-20-2013, 08:14 AM - Thread Starter
sdss's Avatar
i bn asking this question no answer . well one guy told me to put it @ 180hz the sub .
ok i got a BIC AMERICA F12 , http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361373056&sr=1-1&keywords=bic+america+f12
and polk Audio Tl150 http://www.amazon.com/Polk-Audio-TL150-Speaker-5-pack/dp/B0043M666I/ref=sr_1_2?ie=UTF8&qid=1361373016&sr=8-2&keywords=polk+150
and a crappy receiver, http://www.amazon.com/Sony-STRDH520-Channel-Receiver-Black/dp/B004NHCGJO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361373103&sr=1-1&keywords=sony+receiver+7.1
i'm noob to audio stuff so i was wondering in the receiver i set it to small speakers , but what crs should i use for the speakers .
and on the sub what hz should i use 40-180hz? Thanks
sdss is offline
post #2 of 8 Old 02-20-2013, 10:32 AM
m_vanmeter's Avatar
the published spec for the "low end" of the small TL150's is 120 Hz, so setting the crossover at 180 Hz is correct....definitely no lower than 120 Hz
m_vanmeter is offline
post #3 of 8 Old 02-20-2013, 11:27 AM - Thread Starter
sdss's Avatar
the receiver puts the crs to 120hz for each speaker should i leave it like that or make it 140-150?
sdss is offline
post #4 of 8 Old 02-20-2013, 11:34 AM
Bill Fitzmaurice's Avatar
Liked: 4745
The higher the crossover the more directional frequencies will be sent to the sub. You don't want that. Ideally you don't want anything higher than 80Hz going into the sub. That, of course, means that the L/R/C should be able to go to 80Hz. If they can't you just have to go as low as they'll tolerate.
Bill Fitzmaurice is offline
post #5 of 8 Old 02-20-2013, 08:32 PM - Thread Starter
sdss's Avatar
i get to put the crossover on the subwoofer to 180hz but idk if the speaker can go down to 80hz. I'm sure they can't that's why I'm asking what crs does my speaker can handle should i just leave it at default on the receiver @ 120hz . another guy told me to put to to 140-150hz because something to do with, Lower -3dB Limit: 125Hz, Upper -3dB Limit: 20kHz , Frequency Response 95Hz-22kHz
sdss is offline
post #6 of 8 Old 02-21-2013, 03:04 AM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1826
Max out the crossover on the sub and, because the speakers extend to 125Hz @ -3dB, set the crossover in the AVR no lower than 140Hz.
(The owner's manual indicates that you can adjust the crossover in 10Hz increments, so try 140, 150 and 160 and go with the one that provides the best overall sound.)
eljaycanuck is offline
post #7 of 8 Old 02-21-2013, 06:21 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Regarless wether ur speaker will go down to 80hz or, i think you can try crossing them over around 100hz. the higher u cross the more directional it becomes the sub and i bet it will sound like crap. You have to understand that even when your front cant reach very low, but crossing to a high pass remove alot of low frequencies sent to the front , so your speaker will still benifit from high passing.
RicardoJoa is offline
post #8 of 8 Old 02-21-2013, 06:35 AM - Thread Starter
sdss's Avatar
Thanks all. and thanks @ eljaycanuck that's what i will do
sdss is offline
Reply Speakers
