Need advice - converting from 5.1 to 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-20-2013, 11:25 PM - Thread Starter
Dan-Tron's Avatar
Hello. I could really use some advice on speakers. I'm not educated on speakers at all. Looking around, the choices are endless and I'm having troubles knowing what I really need.
Here's the situation:
My space is 14ft x 18ft.
I have four KLH Model 900B, 8 Ohm, 50-20000Hz speakers.
I have a Polk Audio center with missing info sticker (it fell off).
I got a new Marantz SR6007 receiver and I wish to upgrade to 7.1 speakers.
I think my existing speakers sound pretty good, but maybe I don't know any better?
I'd like to amend my speaker setup without having to buy all new speakers.
Are there any recommendations for any experts out there?
I was thinking of maybe getting two new front speakers and using my KLH speakers for surround and back channels. If I do that I'm not sure where to begin finding a good pair that would match up well.
Dan-Tron is offline
post #2 of 5 Old 02-20-2013, 11:33 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Yep. Good way to go would be to replace the front left/right and center. It's important for all three of those to timbre match for a good front soundstage.
Then again, perhaps you could load a picture of your Polk center channel? Take the grill off, first. Someone might be able to tell you what speakers might match.
What is your budget?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 5 Old 02-21-2013, 12:04 AM - Thread Starter
Dan-Tron's Avatar
Here's some photos I just took of the front and center speakers. Excuse the dust as I'm doing construction. :-)
As far as budget goes, maybe around $200ish. If that's totally unrealistic for what what I am doing, I could probably bump it up a little bit.
Dan-Tron is offline
post #4 of 5 Old 02-21-2013, 05:42 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Your options are limited with $200 for your front three, but here is what I would get:
BIC DV62si for your fronts http://www.amazon.com/BIC-America-DV62si-Bookshelf-Speakers/dp/B00006JPDI/ref=sr_1_1?ie=UTF8&qid=1361450375&sr=8-1&keywords=bic+speakers
BIC DV-62CLRS for your center http://www.amazon.com/BIC-America-DV-62CLRS-Channel-Speaker/dp/B00009WBYL/ref=pd_sim_e_1
You could also look at the Pioneer BS22 and C22, or if you can accommodate a bookshelf speaker for your center, three Infinity Primus P153.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 5 Old 02-21-2013, 07:17 PM - Thread Starter
Dan-Tron's Avatar
Thanks for the advice. I think I will give the BIC's a try. Based on the reviews of them I see they are a real good bang for the buck.
Dan-Tron is offline
Reply Speakers
