Klipsch RF 42 II Vs Klipsch Synergy F-2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-21-2013, 02:29 PM - Thread Starter
johnydub's Avatar
I already own a pair of Klipsch Synergy F-2's and just purchased a pair of Klipsch 42 RF's at a decent price. Which speakers should I be using as my fronts and which for my rears? Currently using a Velodyne 4000 SLR sub as well.
thanks!
johnydub is offline
post #2 of 6 Old 02-22-2013, 04:52 PM
eaux's Avatar
Liked: 25
What is your center speaker? Ideally you want to have the fronts and center timbre-matched. So if your center is matched to the F-2's as in an existing setup, keep them as the fronts.
eaux is offline
post #3 of 6 Old 02-22-2013, 09:46 PM - Thread Starter
johnydub's Avatar
I don't currently have a center, that will be my next purchase. Should I be looking at a rc 42 then?
johnydub is offline
post #4 of 6 Old 02-23-2013, 07:33 AM
cchunter's Avatar
Quoted: 495 Post(s)
Liked: 772
If your using the RF42's for fronts then yes get the RC42.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Oppo 203 Sony PS4
Panamax 5300PM
Sony 65XBR850D 4K
cchunter is offline
post #5 of 6 Old 02-23-2013, 08:13 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The RF is a higher end product line than the Synergy but you got the small towers with only 4.5" woofers. It doesn't play nearly as low as the Synergy F-2 which has dual 6.5" woofers.
I would try both as fronts and then decide which ones would I like better, then buy the corresponding center. If you're not going to add a subwoofer, the larger F-2 would be better as fronts since they play quite a bit deeper.
Afro GT
afrogt is offline
post #6 of 6 Old 02-23-2013, 02:51 PM
eaux's Avatar
Liked: 25
+1
At least get a budget sub and put the RF-42's at the front. You can order the Klipsch RW-12d for real cheap from newegg this weekend. Then set your 42's as small and cross the sub at 80Hz.
eaux is offline
Reply Speakers
