Need help. I have a pair of Polk rti12's, csi5 center, and a pair of rtis,6 - AVS Forum
post #1 of 7 Old 02-21-2013, 06:11 PM - Thread Starter
paul112233's Avatar
I purchased an onkyo tx nr808 receiver, and I just purchases a Denon 2 channel 220 watts per channel amp. Should I ruN the amp to each tower. Or should I bi amp the highs with the onkyo and use the amp to power the lows on the rti12s.
Not sure which is best for the best sound for music and movies.
If I bi amp with the receiver will it still have enough power to run the center and the surrounds. Or will the amp be plenty of power to drive the tower rti12s alone. Your advice would be much appreciated.
Thank you
paul112233 is offline
post #2 of 7 Old 02-21-2013, 09:48 PM
crazyrob425's Avatar
Quoted: 118 Post(s)
Liked: 168
Let the amp either handle all the rti12's or don't us it at all. Don't break it up
You will have plenty of power to run all your speakers with just the 808 alone.
crazyrob425 is offline
post #3 of 7 Old 02-22-2013, 08:36 AM - Thread Starter
paul112233's Avatar
I am just not getting any bass from my towers. I have it set to full tower on the reciever, and I also have the low end db set up as well. Will the new amp help me get
post #4 of 7 Old 02-22-2013, 08:37 AM - Thread Starter
paul112233's Avatar
Some low end from my towers.
post #5 of 7 Old 02-22-2013, 08:47 AM
Quoted: 118 Post(s)
Liked: 168
Yes hooking the towers up to a Denon 2-channel amp should increase the bass. Hook the RTi12's to the amp alone.
post #6 of 7 Old 02-22-2013, 09:51 AM - Thread Starter
paul112233's Avatar
Thankyou
post #7 of 7 Old 02-22-2013, 10:48 AM
cel4145's Avatar
Quoted: 212 Post(s)
Liked: 746
You don't have a sub? If you are depending on those towers to provide good deep sub bass for movies, might not happen.
If more mid bass is what you are looking for, still might not happen. Could be the room acoustics and the placement of the speakers relative to the listening position is inhibiting good response at certain frequencies.
So if the amp doesn't do it, don't be disappointed.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is offline
Reply Speakers
Polk Audio Speakers Rti 12
User Tag List
