inexpensive speaker wire insulation changing color over time.is this normale? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2013, 07:22 AM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
will this disscoloration effect the preformance of the audio signal.
Here is my Monoprice AWG12 two years old laying next to new Monoprice.
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 3 Old 02-22-2013, 08:44 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
Are you sure it's the insulation changing color and not the copper on the inside? The former is harmless, the latter is not.
tsaville is offline
post #3 of 3 Old 02-22-2013, 09:19 AM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 134
Yeah, it's the copper inside that has changed color due to perfectly normal copper oxidation. The insulation is clear; you can see the copper inside it. Over time, the older wire may or may not develop shorts. Until it does, I wouldn't worry about it. If it develops a short, replace it. It's not a big deal. Copper exposed to air or water will oxidize and turn greenish. It's just chemistry.
Will2007 is offline
Reply Speakers
