Speaker upgrade :) and downsize :( - AVS Forum | Home Theater Discussions And Reviews
Old 02-23-2013, 05:42 PM - Thread Starter
esmalley007's Avatar
Hello,
I purchased a new house with my girlfriend which does not have a dedicated media room so I have decided to downsize my equipment a bit but at the same time upgrade in quality.
Currently I have the following:
Front LR: Bic America Dv64 6.5 Tower Speaker
Center: BIC America DV-62CLRS
SR: BIC Venturi DV32-B
Sub: Dayton Audio SUB-100 HT
I know it's a pretty entry level system but it has served me fine for now. I am looking to replace the floor-standings with bookshelf or smaller fronts and hopefully a matching smaller center. I will be buying in-ceiling surrounds since there are french doors behind the sofa. I will either keep the existing sub, if I can find a place for it, or not use one at all.
After doing some research I came up with the following. Please let me know what you think. Budget is 500-600 but less would be great!
Front LR: EMP Tek E5Bi Bookshelf
Center: EMP Tek E5Ci Center Channel Speaker
SR: Polk Audio RC60i
I was also wondering if thePolk Audio Blackstone TL3 were a good option. Thanks!
esmalley007 is offline
Old 02-23-2013, 05:57 PM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
I suggest that you consider the Cambridge Audio S30, S50 and S20 speakers.
IMO that would give you better sound.
All of those speakers are very good; especially the S50 center speaker.
About $570 total.
commsysman is offline
Old 02-23-2013, 09:12 PM
Elihawk's Avatar
Quoted: 1017 Post(s)
Liked: 861
The EMPtek bookshelfs are very good and will be AS GOOD as anything in that price!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 02-23-2013, 09:23 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Not to derail this...I see 3 different EMP bookshelf micro..two normal...
I can't figure out the big differance between the two models..any help?
Newbie01 is offline
Old 02-24-2013, 02:29 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
What's your listening mix of HT/TV vs Music?
sdg4vfx is offline
Old 02-24-2013, 07:41 AM - Thread Starter
I would say 90% movies and 10% music, probably through apple tv. Thanks!
