Polk Monitor 75T Experience - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2013, 09:37 PM - Thread Starter
GaryWA's Avatar
Quoted: 16 Post(s)
I finally had a chance to sit down in the quiet and listen to some music. Well, to start off, I'll say I'm a little disappointed, but I shouldn't expect much for $440.
The highs are too harsh, and feels a bit lacking at times. (I know this is the "Polk" sound)
It felt like the mids and the highs were clashing, it wasn't very clear, like they were fighting each other.
My music just isn't as clear and full as I thought it would be. For example, if I listen to a rock song, the drum cymbals and guitar would essentially take over everything, don't know how to explain it, just didn't sound too good.
Guess I'll save up for some PSB Imagines!
GaryWA is offline
post #2 of 5 Old 02-24-2013, 06:49 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
What were you using to feed music to the speakers?
What amp/receiver were you using?
Have you attempted to use the EQ on the receiver?
I have found with Polks for music I just keep the grills on, don't angle them to the listening position, and lower the treble by one notch the highs are smoothed out
crazyrob425 is offline
post #3 of 5 Old 02-24-2013, 12:46 PM - Thread Starter
GaryWA's Avatar
Quoted: 16 Post(s)
iPod Touch connected with line out USB cable playing all ALAC files
Pioneer SC-1222-K
MCACC set the EQ, but I guess I could reduce the treble and see if it improves a little.
GaryWA is offline
post #4 of 5 Old 02-24-2013, 12:48 PM
Threefiddie's Avatar
Quoted: 412 Post(s)
Liked: 187
I have 75ts
mind = blown is how I sum it up
but I don't listen to music on home theater setup personally, but loving my 75ts, 45bs, 25c.
trying my luck with sony a1e after what feels like being in jail when I look at 2 lg c7's I've had. Jailbars you can see in movies and games isn't acceptable for this kind of money. LG calls it "normal" maybe sony won't with same panel.
Threefiddie is offline
post #5 of 5 Old 02-24-2013, 04:08 PM
Quoted: 445 Post(s)
Liked: 339
Pioneer SC-1222-K
Yeah I would reduce the treble also make sure your volume on the ipod is not at the max level as well you want it at 80-85% max
Reply Speakers
