question on negative/postive terminals - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-24-2013, 06:40 PM - Thread Starter
xkaijinx's Avatar
I have my speaker wire going under the rug.
Now as I go to set this up I realize I did not mark the ends and cannot follow which end is going to where.
If I plug a black plug into a black end, whereas the correlating end is mixed up and ends up going into a red terminal is this going to 'break' my speakers/system?
or will it just not work and I can switch the ends to the right plug?
xkaijinx is offline
post #2 of 2 Old 02-24-2013, 07:01 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
It won't break anything but if there plugged in wrong your sound might be funny and be what we call:out of phase.
Doing what I do best...LIVIN!
josh6113 is offline
Reply Speakers
