Want to match center and surrounds to my DefTech Mythos Ones. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-24-2013, 05:46 PM - Thread Starter
agray88's Avatar
Quoted: 14 Post(s)
Hi all. I'm new to the forum! I have a pair of DefTech Mythos Ones I'd like to use as the foundation of a 5.1 home theater. Room is 14 x 15 x 8' and is located in a finished basement. I have the DefTech Prosub 800, which seems like plenty of sub, given the size of the room. I'm running this through a Denon 1909 AVR, which I plan on upgrading soon due to lack of 3D capability, and Epson 5010 projector. I was debating between the Mythos Seven and the Nine for the center channel and the Gem and the Gem XL for the surrounds. Keep in mind I plan on installing sound panels to optimize acoustics. So could I get away with the Mythos Seven with Gem surrounds, or should I go all in with the Nine and Gem XLs? Or are there other center and surround options I'm not considering? Any feedback is greatly appreciated.
Adam
AVR: Anthem AVM60 - Amp: McIntosh MC205 - DAC: PS Audio DSD NuWave - Phono stage: PS Audio Phono Converter - Turntable: ClearAudio Concept with Ortufon Black cartridge - Power: PS Audio P10 power regenerator - Speakers: Def Tec 8060s - Subx: JL Audio Fathom 110 x 2 - Blu Ray: Yamaha BD-S473 - Projector: Epson Powerlite 5020 - Music Server: Mac Mini with Roon and JRiver
agray88 is offline
post #2 of 3 Old 02-27-2013, 09:20 AM - Thread Starter
agray88's Avatar
Quoted: 14 Post(s)
After talking to DefTech, they recommend the Mythos Nine center with the Gem XL surrounds. But that is what I would expect them to say in recommending the better, more expensive speakers. They did say the Prosub 800 should be plenty for that size room. Any thoughts?
agray88 is offline
post #3 of 3 Old 02-27-2013, 11:03 AM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
HT usually means you should sink your money into your center and your sub. You are happy with your sub...so go with the better center.
Just a rule of thumb that can be broken 10 ways but:
HT= Center and Sub (Most important)
Music 2.0 = L/R (sometimes sub depending on how low your L/R can go)
Mix HT / Music - Front sound stage L/C/R and Sub
HT + Multichannel sound = All are important
Again, exceptions to every rule like Phantom Center etc etc...but it is a decent rule of thumb to go by.
Also, you normally should stay within same family / brand of your front sound stage...
Newbie01 is offline
Reply Speakers
