Speaker pair $150-$200??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-24-2013, 10:49 PM - Thread Starter
Beees's Avatar
I'm looking to start a 5.1 system with a refurb denon 1612. I am looking at a new sub, and need some speakers to start my system. From looking at other threads, this will be a "budget system." I don't have thousands of dollars to spend on speakers. I was hoping to get some suggestions on what to pair with my receiver for my L/R front speakers. I am looking to spend about $150-$200 for a pair of speakers. Obviously, I'm new to the whole audio thing so any advice or suggestions would be greatly appreciated. Thanks!
Beees is offline
post #2 of 17 Old 02-25-2013, 12:03 AM
killershark88's Avatar
I would reccomend the Cambridge Audio s30 bookshelf speakers, they sound amazing and are around $220, and the matching center is great too (s50).
http://www.avhifi.com/shop/cambridge-audio-s30-speakers.html
http://www.avhifi.com/shop/cambridge-audio-s50-center-speakers.html
killershark88 is offline
post #3 of 17 Old 02-25-2013, 10:29 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 Would be extremely difficult to get a better speaker at that price point. Amazon also carries them.
sdg4vfx is offline
post #4 of 17 Old 02-25-2013, 12:54 PM
onkyoKURD's Avatar
im trying to replace my 6 ohms speakers with 8 ohms?
i want new setup speakers for my sr607 as well?
onkyoKURD is offline
post #5 of 17 Old 02-25-2013, 04:49 PM - Thread Starter
Beees's Avatar
Thanks guys. Are there any other recommendations? I posted a similar thread about a subwoofer in the subs section, and of course the replies are that I should up my budget on that also. I could spend more on one probably, but not both. If you had to choose, would you sink more money into the front speakers or the sub?
If the answer is sub, are there some other, cheaper recommendations for speakers? I probably sound pretty annoying, but I appreciate any help.
Beees is offline
post #6 of 17 Old 02-25-2013, 05:10 PM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
http://www.accessories4less.com/make-a-store/item/BOSA25GB/BOSTON-ACOUSTICS-A25-2-Way-5.25in-Bookshelf-Speaker-Each-Gloss-Black/1.html
You can only go so cheap before you start lowering the quality.
Afro GT
afrogt is online now
post #7 of 17 Old 02-25-2013, 05:18 PM
Elihawk's Avatar
Quoted: 1029 Post(s)
Liked: 869
The def tech sm350/450 bookshelves can be had for 200/pr! The matching center can be hard to find, but they are a very nice bookshelf speaker for 200 bills or less!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #8 of 17 Old 02-25-2013, 05:26 PM - Thread Starter
Beees's Avatar
I looked for the cambridge audio s30s on amazon and couldn't find them...
Beees is offline
post #9 of 17 Old 02-25-2013, 05:36 PM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15849
fwiw take a look at the audio advisor great little speakers with big sound. highly recommended in your budget
i'm so laid back,i'm laid out
smasher50 is online now
post #10 of 17 Old 02-25-2013, 07:20 PM - Thread Starter
Beees's Avatar
So I was looking for those cambridge audio speakers on amazon because I have an amazon gift card I have yet to use. Its for $50, so it would definitely help my budget if I could find some good options on amazon.
As always, thanks for the help.
Beees is offline
post #11 of 17 Old 02-25-2013, 07:24 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Check out NHT...can even pick them up used for cheaper. They measure very flat...sound good and come highly recommended.
These come highly recommended as well: Dayton Audio B652 6-1/2-Inch 2-Way Bookshelf Speaker Pair -- these are on Amazon for 50 bucks as well.
Newbie01 is offline
post #12 of 17 Old 02-25-2013, 07:38 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
It's right here (albeit not many in stock):
http://www.amazon.com/Cambridge-S30-N-Speakers-Black-Pair/dp/B004DAN3GQ
That would be compromising a bit much for front speakers. With a $50 gift card and some additional funds available, the S30 would be a much better choice in the long run, in my opinion.
Robert Cook is offline
post #13 of 17 Old 02-25-2013, 07:38 PM
You can find them and all of the Cambridge audio S series speakers on Av Hi Fi, it uses Amazon as a payment method so you can probably use the $50 gift card there
http://www.avhifi.com/shop/cambridge-audio-s-series-speakers.html
post #14 of 17 Old 02-26-2013, 04:05 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
The S30's go in and out of stock regularly on Amazon. When they're out of stock it usually lasts less than a week.
If you have an Amazon Prime membership you get 30 day return plus free return shipping on most Amazon items - including the S30's.
I've had the Prime membership for so long I don't remember what the regular/non-prime return/return-shipping policies are ; )
sdg4vfx is offline
post #15 of 17 Old 02-26-2013, 04:54 AM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15849
fwiw,pretty much you can go to any speaker review and get the exact same highly recommended response from all.i would say that a majority of the reviews come from people who have heard nothing but tv speakers,radio, or some type of home theater in box satalites. i own the s-30's in my small listening room and the dayton b652's in a 5.1 garage theater for the grandkids (did'nt want any thing to expensive with 4 grandkids and their neighborhood friends horseplaying ).i would definitly pay the extra $200 for the s-30's
post #16 of 17 Old 02-26-2013, 05:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Infinity Primus P163 speakers are right in your price range, and IME fine sounding speakers.
There is even an extant Stereophile review of its very similar predecessor with both technical and subjective comments:
http://www.stereophile.com/standloudspeakers/1007inf/
Here is a subjective review comparing it to other options: http://www.soundstage.com/equipment/infinity_primus_p162.htm
arnyk is offline
post #17 of 17 Old 02-27-2013, 04:10 PM - Thread Starter
Beees's Avatar
Well the s-30s are out of stock on amazon, and I went to Av Hi Fi, but there's no place to enter an amazon gift card code. So I guess I'm waiting until Amazon gets them in stock again. Thanks for the help gentlemen. Now I just need to find my sub...
Beees is offline
Reply Speakers
