Klipsch RW 12D with Denon 1913 - Not Recognizing. Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 02-25-2013, 11:52 AM - Thread Starter
chintu30's Avatar
Hi All,
I just set up the following -
1. Energy 5.0 speakers
2. Denon 1913 AVR
3. Klipsch RW 12d
As others have stated on this thread, inititally I did get a small thump on the sub. But after I ran Audyssey again after fully setting things up quite a few times, it won't recognize the Sub at all! I have tried setting the volumes on the sub from -20 - 0db no luck! Here are my settings -
1. I set the Speakers to SMALL
2. Bass -
Subwoofer mode - LFE+Main
LPF - 120hz
3. Distances seemed fine on all the speakers, but it had 13ft on the Sub which was right next to the left speakers which were set to 8ft.
4. Test tone -
Front L - 0 db
Front R - +0.5 db
Center - -0.5 db
Surround R - +1.0 db
Surround L - 0.5 db
Sub Woofer - 6 db
5. Crossover
Front - 80 Hz
Center - 80 Hz
Surround - 80hz
On the Sub -
6. Volume - -23db
7. Phase 0
8. LFE off
I am concerned and I hope its not the sub itself...Because there was a point when I got the thumps! Any help would be greatly appreciated!
Regards
chintu30 is offline
post #2 of 29 Old 02-25-2013, 12:03 PM
Alan P's Avatar
Quoted: 5135 Post(s)
Liked: 3830
Originally Posted by chintu30 View Post
2. Bass -
This is your problem. LFE+Main with your FL/R set to small = no output to sub.
Set that to LFE and you should be good to go!
Alan P is offline
post #3 of 29 Old 02-25-2013, 01:40 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Originally Posted by Alan P View Post
LFE+Main with your FL/R set to small = no output to sub. !
the LFE & LFE+Main settings do not apply when speakers are set to small.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #4 of 29 Old 02-25-2013, 01:51 PM - Thread Starter
chintu30's Avatar
So its possible that changing that to LFE should help?
chintu30 is offline
post #5 of 29 Old 02-25-2013, 02:05 PM
Alan P's Avatar
Liked: 3830
Really? They sure effect the output on my AVR (Denon 2113ci). When I have the mains set to small and turn on LFE+Main I get absolutely no output (or very little output) from my sub unless I set the mains to large. confused.gif
It should, can't hurt to try.
EDIT: OK, holt is correct - the LFE+Main setting does nothing if your mains are set to small. Don't know what I was thinking!! rolleyes.gif
Alan P is offline
post #6 of 29 Old 02-25-2013, 02:23 PM
Alan P's Avatar
Liked: 3830
OK, back to the OPs problem -
When you run your AVRs internal test tones, does the sub make noise? I'm assuming it does since you didn't say that Audyssey came up with an error and it actually set your sub level.
Not sure what you mean when you say " it won't recognize the Sub at all!" - did Audyssey detect your sub? Once again, I'm assuming it did since you listed a level for the sub.
Also, not quite sure what you mean when you say "no thump" - is the sub making noise at all? What program material are you using to test the sound of the sub?
Alan P is offline
post #7 of 29 Old 02-25-2013, 02:39 PM - Thread Starter
chintu30's Avatar
So - I have been running through the setup a few times. The Audyssey did detect the Sub once. At that time the sub wasn't loud at all and I barely heard a thump from it. But when I tried running it again - Audyssey hasn't detected the Sub since. The sub made no noise at all.
The level I showed was under the Test Tone under Manual setup at 6db.
I have tried the following -
1. Increasing the volume on the Sub itself.
2. Changed the crossovers for the Front, Center & Surrounds to 80 Hz.
3. LFE at 120Hz and OFF on the Sub itself
3. I have also double checked if the Sub works, by connecting it directly to the TV and got bass out of it (which was one of the things Klipsch Customer Service asked me to do).
chintu30 is offline
post #8 of 29 Old 02-25-2013, 02:47 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
This is what I'd like to know as well.
holt7153 is offline
post #9 of 29 Old 02-25-2013, 02:52 PM - Thread Starter
chintu30's Avatar
No it does not make any noise when I run the AVR's test tones.
chintu30 is offline
post #10 of 29 Old 02-25-2013, 02:57 PM
XStanleyX's Avatar
Liked: 1270
You say in item #3 you have the sub set to off? Should be on. Maybe I'm not reading it right?
XStanleyX is offline
post #11 of 29 Old 02-25-2013, 03:03 PM - Thread Starter
chintu30's Avatar
Well I tried both - Keeping it at 120Hz and switched OFF on the Sub. I read elsewhere on this Forum that turning it OFF on the Sub would allow the AVR to control it. But either way - I tried both!
chintu30 is offline
post #12 of 29 Old 02-25-2013, 03:12 PM
Alan P's Avatar
Liked: 3830
How did you get Audyssey to set the sub level without it functioning? Anyway....
Do you have the sub connected via RCA cable to the subwoofer output on your AVR?
Have you tried a different RCA cable?
In your AVR, do you have the subwoofer set to YES?
Is your sub's gain knob turned up at least half way?
Is your sub plugged in? (Sorry, got to ask.)
This is the correct way to set the LFE on your sub, you should be good there.
Alan P is offline
post #13 of 29 Old 02-25-2013, 03:24 PM - Thread Starter
chintu30's Avatar
Yes, The RCA cable is connected to subwoofer output on AVR and Left Line In on the Sub.
I haven't, I will give this a shot today
I did, during the Audyssey setup - it went through all the speakers and even showed that it was trying to get a signal from the Sub (with it highlighted on the screen), but couldn't get one.
Its digital, I set the volume at around -20 - -15db
chintu30 is offline
post #14 of 29 Old 02-25-2013, 03:41 PM
Alan P's Avatar
Liked: 3830
When you try a different cable you might as well try the other (right) input on the sub.
Do you have a different audio source you could try the sub with? Could be the sub out on your AVR went t*ts up...unlikely, but it happens.
Alan P is offline
post #15 of 29 Old 02-25-2013, 03:48 PM - Thread Starter
chintu30's Avatar
I have an Apple TV & PS3. What is the best way to connect these directly to the Sub.
Again your help is greatly appreciated, thank you very much for taking the time!
chintu30 is offline
post #16 of 29 Old 02-25-2013, 04:02 PM
Alan P's Avatar
Liked: 3830
If you have anything with a headphone out (iPod, iPhone, etc.) and a headphone jack to RCA adapter it would be easy to get a signal to the sub to see if it's actually working.
Alan P is offline
post #17 of 29 Old 02-25-2013, 07:52 PM - Thread Starter
chintu30's Avatar
Ok, so I just tried both - connected an iPod, the sub worked as well as with a different RCA cable. So it seems like that cable was faulty! :s
Now for the tuning - I did the Audyssey calibration with LFE OFF, Phase at 0 and Volume at -15db on the Sub. Audyssey finally recognized the Sub! smile.gif
Front L - + 2.0 db
Center - + 3.0 db
Front R - + 0.5 db
Surround R - +3.5 db
Surround L - 2.0 db
Subwoofer - - 6.0 db
Crossovers -
Individual
Front - 80 Hz
Center - 60 Hz
Surround - 80 Hz
The Sub is working on songs too, but not nearly recognizable unless I increase the volume to full on it.
chintu30 is offline
post #18 of 29 Old 02-25-2013, 08:16 PM
Alan P's Avatar
Liked: 3830
YEAH! So glad it was something simple...it's always the cable, right? wink.gif
So - how does it sound now with movies?
It's usually recommended that you now raise all your crossovers to 80hz and make sure all speakers are set to "small". This will probably increase your bass with music a bit, but there are other things that can help even more - What surround mode are you using when you're listening to music? Are you using Dyanmic EQ? You've turned OFF Dynamic Volume, right? What source are you using for music/what format/bitrate?
If you're obsessive like me, you could raise you sub volume to -10 (on the sub) to get Audyssey closer to 0db on it's calculations - but that's probably not neccessary. rolleyes.gifbiggrin.gif
Alan P is offline
post #19 of 29 Old 02-26-2013, 10:54 AM - Thread Starter
chintu30's Avatar
So - I watched 'Life' last night. Again - the sub was a little underwhelming, unless I manually increased the volume on the Sub. Another thing I noticed was that dialogues on the center channel kept going high and low, not sure why. Is it adjusting the volume automatically?
Settings -
1. Surround Mode - 'Movie' on the AVR remote
2. Dynamic EQ - I must check but I believe it was ON - Should it be OFF?
3. Dynamic Volume - Not sure, have to check this - Should it be OFF?
3. Will reduce Sub volume to -10, should I run Audyssey again after this? Is there any way to just run Audyssey on the Sub and not everything?
4. Will change the Crossovers on all speakers to 80 Hz, they are all SMALL
chintu30 is offline
post #20 of 29 Old 02-26-2013, 11:34 AM
Alan P's Avatar
Liked: 3830
It's kind of a matter of preference, but most prefer it on. Play around with the "Reference Offset" until you get a mix of bass and surround that sounds good to you. As a general rule, most people set Blu Ray sources to 0db offset and TV to 10 or 15db offset.
That's Dynamic Volume doin' it's thing.
Yes, you need to re-run Audyssey after changing anything in your setup (sub volume, speaker positions, listening positions, furniture placement, etc.). No, you can't just run Audyssey for the sub - it's the Full Monty of nothin'.
If you're gonna adjust the sub volume to try to get Audyssey to set it closer to 0db, you can just run the first Audyssey position until you get it where you want it, then run all Audyssey mic positions.
Is that the Eddie Murphy film? I wouldn't expect much bass from any comedies (there are exceptions), especially one from 1999. rolleyes.gif Try something from this decade. Some new ones with great LFE that I've recently watched are SkyFall, Looper, Total Recall (new version) and The Dark Knight Rises.
Alan P is offline
post #21 of 29 Old 02-26-2013, 11:52 AM - Thread Starter
chintu30's Avatar
Awesome thanks again...will try all those.
chintu30 is offline
post #22 of 29 Old 02-26-2013, 03:14 PM
skidog's Avatar
Liked: 27
I don't think an animal documentry is going to give much bass. Unless it's a stampeding herd of Wildabeast(sp?) or a herd of Elephants storming the camera man eek.gif
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #23 of 29 Old 02-26-2013, 03:15 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
ack_bk is online now
post #24 of 29 Old 02-26-2013, 03:33 PM
Alan P's Avatar
Liked: 3830
Chintu - you didn't list it in your equipment, but you DO have a Blu Ray player, right??
Alan P is offline
post #25 of 29 Old 08-07-2013, 05:08 PM
wargod's Avatar
Quoted: 46 Post(s)
Is there any way to lock the fronts as small and the sub at LFE before running Audessy? When I run it, it changes the "small" setting and crossover settings. Are you guys saying to just run the test setup and then manually change the fronts to small and crossover to 80hz?
Do you keep the sub setting at 120hz on the sub itself and the AVR1913 sub setting at 120hz as well, or do you run it at a lower frequency?
wargod is offline
post #26 of 29 Old 08-07-2013, 05:59 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Yes. Your receiver will set the crossover to the lowest possible value around where the speakers roll off. If this is below 80hz, then try 80hz as the crossover instead. And yes. You have to set to small. The receiver defaults to large because it doesn't know what you intend to do with the speakers.
Set your sub to the highest possible crossover or (better) to crossover bypass mode if one is available. Your receiver will completely handle the crossover with the speakers. There is a LFE specific channel setting on Denon receivers which should be left on 120hz. This is the ".1" in 5.1 audio recordings meant to go to the sub. Meanwhile, the regular per speaker crossover reroute the lower bass from the other 5.0 speaker channels to the sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #27 of 29 Old 08-07-2013, 07:16 PM
wargod's Avatar
Quoted: 46 Post(s)
Should the power to the sub be left on?
wargod is offline
post #28 of 29 Old 08-07-2013, 07:39 PM
cel4145's Avatar
Liked: 3002
Sure. Unless you want to turn it on/off each time smile.gif
cel4145 is offline
post #29 of 29 Old 08-07-2013, 07:55 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
LIFE has lots of Bass in the music... (the movie)
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
Reply Speakers
