Denon 1612 speaker wire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-27-2013, 08:13 PM - Thread Starter
Beees's Avatar
I recently got a Denon 1612 and am going to purchase some Cambridge Audio S30s when Amazon gets them back in stock. I am a very new to audio and was wondering what the almighty forum would recommend for speaker wires with this setup. I'm fairly handy, so I don't thinking hooking up the speakers will be a problem, just dont know what size/connections I need. Sorry for being oblivious. Thanks for the help!
Beees is offline
post #2 of 12 Old 02-27-2013, 08:27 PM
Bill Fitzmaurice's Avatar
Liked: 4629
Monoprice and Blue Jeans are good sources. Use this to figure the gauge requirements:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Connectors are optional; I don't bother with them.
Bill Fitzmaurice is offline
post #3 of 12 Old 02-28-2013, 12:22 AM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
14 gauge is fine and I love banana plugs for the tidy connection . Lots of places including ebay to get them.
chalugadp is offline
post #4 of 12 Old 02-28-2013, 05:26 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
monoprice...all you will ever need!
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #5 of 12 Old 02-28-2013, 08:32 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
www.audioadvisor.com has the Cambridge in stock. Same price that Amazon sells them for.
http://www.audioadvisor.com/prodinfo.asp?number=CAS30%20%20%20%20%20DKOAK
matching s50 center
http://www.audioadvisor.com/prodinfo.asp?number=CAS50%20%20%20%20%20BLK
14ga speaker wire is fine. Monoprice.com has great quality and pricing.
Afro GT
afrogt is online now
post #6 of 12 Old 03-02-2013, 01:02 PM - Thread Starter
Beees's Avatar
Thanks for the help guys. I will pick up some 14 gauge wire for my speakers. I'm waiting for amazon because I have a gift card there. Again, thanks for the help!
Beees is offline
post #7 of 12 Old 03-02-2013, 02:18 PM - Thread Starter
Beees's Avatar
After looking at monoprice, is there any difference in the banana plugs?
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10401
They are all similar in price, I just wondered if there was something I needed to be aware of before I just ordered some (open wire vs. closed wire). As always, thanks for putting up with me.
Beees is offline
post #8 of 12 Old 03-02-2013, 05:47 PM
afrogt's Avatar
Liked: 755
Honestly, after using the Monoprice closed screw plugs and several other banana plugs I've found these are the best banana plugs for me.
http://www.amazon.com/Sewell-Deadbolt-Banana-Fast-Lock-Technology/dp/B006U3O566/ref=pd_sim_pc_3
The monoprice plugs are fine but the Sewell plugs are much easier to use. I also like the Sewell outer casing better since it is non-metallic. They're worth the extra cost.
Afro GT
post #9 of 12 Old 03-02-2013, 05:57 PM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
They even have a rubber grommet where they screw together. Nice touch. I have not used this kind and dont need any now but I will check them out next time.
Licence to Kill
Bond 007 is offline
post #10 of 12 Old 03-02-2013, 06:05 PM
weez82's Avatar
The Sewell's are a little cheaper per pair then the mono price after shipping is calculated (though not by much). And I agree 100%, the Sewell is much nicer to use
weez82 is offline
post #11 of 12 Old 03-02-2013, 06:12 PM
afrogt's Avatar
Liked: 755
Maybe where you live but if you buy the mono price plugs in the 5 pair pack they are $7.66 for 10 plugs. He would need 2 five pair packs which is $15.22. Even with tax and shipping for me it would be $22.76 for 10 sets of plugs.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=9436&seq=1&format=2
I'd still get the Sewell plugs though.
Afro GT
post #12 of 12 Old 03-02-2013, 06:23 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
I've used those mono price plugs and thought they weren't all that great...fit loose on my binding posts of my 8060-st deftech's.I bought speaker cable with bannanas Already attached...there BFA style I believe...very snug fit.
Doing what I do best...LIVIN!
josh6113 is offline
Reply Speakers
